block: replace IS_ERR and PTR_ERR with PTR_ERR_OR_ZERO
Author: Duan Jiong <duanj.fnst@cn.fujitsu.com>
This patch fixes coccinelle error regarding usage of IS_ERR and
PTR_ERR instead of PTR_ERR_OR_ZERO.
Signed-off-by: Duan Jiong
Signed-off-by: Jens Axboe
 block/ioctl.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/block/ioctl.c b/block/ioctl.c
index a31d91d9b..7d5c3b2 100644
--- a/block/ioctl.c
+++ b/block/ioctl.c
@@ -64,7 +64,7 @@ static int blkpg_ioctl(struct block_device *bdev, struct blkpg_ioctl_arg __user
 			part = add_partition(disk, partno, start, length,
 					     ADDPART_FLAG_NONE, NULL);
 			mutex_unlock(&bdev->bd_mutex);
-			return IS_ERR(part) ? PTR_ERR(part) : 0;
+			return PTR_ERR_OR_ZERO(part);
 		case BLKPG_DEL_PARTITION:
 			part = disk_get_part(disk, partno);
 			if (!part)
BtrLinux
Privacy Overview
