block: make PCI device id constant
Author: Márton Németh <nm127@freemail.hu>
The id_table field of the struct pci_driver is constant in
so it is worth to make the initialization data also constant.
The semantic match that finds this kind of pattern is as follows:
(http://coccinelle.lip6.fr/)
@r@
disable decl_init,const_decl_init;
identifier I1, I2, x;
	struct I1 {
	  const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
	struct I1 y = {
	  .x = E,
@c@
identifier r.I2;
identifier s.E;
	const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+	const
	struct I2 E[] = ...;
Signed-off-by: Márton Németh
Cc: Julia Lawall
Cc: cocci@diku.dk
Signed-off-by: Jens Axboe
 drivers/block/DAC960.c | 2 +-
 drivers/block/sx8.c    | 2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/block/DAC960.c b/drivers/block/DAC960.c
index ce1fa92..7412b5d 100644
--- a/drivers/block/DAC960.c
+++ b/drivers/block/DAC960.c
@@ -7134,7 +7134,7 @@ static struct DAC960_privdata DAC960_P_privdata = {
 	.MemoryWindowSize =	DAC960_PD_RegisterWindowSize,
-static struct pci_device_id DAC960_id_table[] = {
+static const struct pci_device_id DAC960_id_table[] = {
 		.vendor 	= PCI_VENDOR_ID_MYLEX,
 		.device		= PCI_DEVICE_ID_MYLEX_DAC960_GEM,
diff --git a/drivers/block/sx8.c b/drivers/block/sx8.c
index a7c4184..7bd7b2f 100644
--- a/drivers/block/sx8.c
+++ b/drivers/block/sx8.c
@@ -409,7 +409,7 @@ static int carm_init_one (struct pci_dev *pdev, const struct pci_device_id *ent)
 static void carm_remove_one (struct pci_dev *pdev);
 static int carm_bdev_getgeo(struct block_device *bdev, struct hd_geometry *geo);
-static struct pci_device_id carm_pci_tbl[] = {
+static const struct pci_device_id carm_pci_tbl[] = {
 	{ PCI_VENDOR_ID_PROMISE, 0x8000, PCI_ANY_ID, PCI_ANY_ID, 0, 0, },
 	{ PCI_VENDOR_ID_PROMISE, 0x8002, PCI_ANY_ID, PCI_ANY_ID, 0, 0, },
 	{ }	/* terminate list */
BtrLinux
Privacy Overview
