block: make Open Firmware device id constant
Author: Márton Németh <nm127@freemail.hu>
The match_table field of the struct of_device_id is constant in
so it is worth to make ace_of_match also constant.
The semantic match that finds this kind of pattern is as follows:
(http://coccinelle.lip6.fr/)
@r@
disable decl_init,const_decl_init;
identifier I1, I2, x;
	struct I1 {
	  const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
	struct I1 y = {
	  .x = E,
@c@
identifier r.I2;
identifier s.E;
	const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+	const
	struct I2 E[] = ...;
Signed-off-by: Márton Németh
Cc: Julia Lawall
Cc: cocci@diku.dk
Signed-off-by: Jens Axboe
 drivers/block/xsysace.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/block/xsysace.c b/drivers/block/xsysace.c
index e5c5415..e1c95e2 100644
--- a/drivers/block/xsysace.c
+++ b/drivers/block/xsysace.c
@@ -1227,7 +1227,7 @@ static int __devexit ace_of_remove(struct of_device *op)
 /* Match table for of_platform binding */
-static struct of_device_id ace_of_match[] __devinitdata = {
+static const struct of_device_id ace_of_match[] __devinitconst = {
 	{ .compatible = "xlnx,opb-sysace-1.00.b", },
 	{ .compatible = "xlnx,opb-sysace-1.00.c", },
 	{ .compatible = "xlnx,xps-sysace-1.00.a", },
BtrLinux
Privacy Overview
