blackfin/irq: Use irq_set_handler_locked()
Author: Thomas Gleixner <tglx@linutronix.de>
Use irq_set_handler_locked() as it avoids a redundant lookup of the
irq descriptor.
Search and update was done with coccinelle.
Signed-off-by: Thomas Gleixner
Cc: Steven Miao
Cc: Jiang Liu
Cc: Julia Lawall
Cc: adi-buildroot-devel@lists.sourceforge.net
Link: http://lkml.kernel.org/r/20150713125611.731615902@linutronix.de
 arch/blackfin/mach-common/ints-priority.c | 8 ++++----
 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/blackfin/mach-common/ints-priority.c b/arch/blackfin/mach-common/ints-priority.c
index 332a434..2eaf83a 100644
--- a/arch/blackfin/mach-common/ints-priority.c
+++ b/arch/blackfin/mach-common/ints-priority.c
@@ -686,12 +686,12 @@ void bfin_demux_mac_status_irq(unsigned int int_err_irq,
 #endif
-static inline void bfin_set_irq_handler(unsigned irq, irq_flow_handler_t handle)
+static inline void bfin_set_irq_handler(struct irq_data *d, irq_flow_handler_t handle)
 #ifdef CONFIG_IPIPE
 	handle = handle_level_irq;
 #endif
-	__irq_set_handler_locked(irq, handle);
+	irq_set_handler_locked(d, handle);
 #ifdef CONFIG_GPIO_ADI
@@ -803,9 +803,9 @@ static int bfin_gpio_irq_type(struct irq_data *d, unsigned int type)
 	if (type & (IRQ_TYPE_EDGE_RISING | IRQ_TYPE_EDGE_FALLING))
-		bfin_set_irq_handler(irq, handle_edge_irq);
+		bfin_set_irq_handler(d, handle_edge_irq);
 	else
-		bfin_set_irq_handler(irq, handle_level_irq);
+		bfin_set_irq_handler(d, handle_level_irq);
 	return 0;
