Blackfin arch: sram: use ‘unsigned long’ for irqflags
Author: Vegard Nossum <vegard.nossum@gmail.com>
Using just 'unsigned' will make flags an unsigned int. While this is
arguably not an error on blackfin where sizeof(int) == sizeof(long),
the patch is still justified on the grounds of principle.
The patch was generated using the Coccinelle semantic patch framework.
Cc: Julia Lawall
Cc: Alexey Dobriyan
Signed-off-by: Vegard Nossum
Signed-off-by: Mike Frysinger
Signed-off-by: Bryan Wu
 arch/blackfin/mm/blackfin_sram.c | 22 +++++++++++-----------
 1 file changed, 11 insertions(+), 11 deletions(-)
diff --git a/arch/blackfin/mm/blackfin_sram.c b/arch/blackfin/mm/blackfin_sram.c
index 1ed1b15..4f5e887 100644
--- a/arch/blackfin/mm/blackfin_sram.c
+++ b/arch/blackfin/mm/blackfin_sram.c
@@ -379,7 +379,7 @@ EXPORT_SYMBOL(sram_free);
 void *l1_data_A_sram_alloc(size_t size)
-	unsigned flags;
+	unsigned long flags;
 	void *addr = NULL;
 	/* add mutex operation */
@@ -402,7 +402,7 @@ EXPORT_SYMBOL(l1_data_A_sram_alloc);
 int l1_data_A_sram_free(const void *addr)
-	unsigned flags;
 	int ret;
@@ -425,7 +425,7 @@ EXPORT_SYMBOL(l1_data_A_sram_free);
 void *l1_data_B_sram_alloc(size_t size)
 #if L1_DATA_B_LENGTH != 0
-	unsigned flags;
 	void *addr;
@@ -450,7 +450,7 @@ EXPORT_SYMBOL(l1_data_B_sram_alloc);
 int l1_data_B_sram_free(const void *addr)
-	unsigned flags;
 	int ret;
@@ -504,7 +504,7 @@ EXPORT_SYMBOL(l1_data_sram_free);
 void *l1_inst_sram_alloc(size_t size)
 #if L1_CODE_LENGTH != 0
-	unsigned flags;
 	void *addr;
@@ -529,7 +529,7 @@ EXPORT_SYMBOL(l1_inst_sram_alloc);
 int l1_inst_sram_free(const void *addr)
-	unsigned flags;
 	int ret;
@@ -551,7 +551,7 @@ EXPORT_SYMBOL(l1_inst_sram_free);
 /* L1 Scratchpad memory allocate function */
 void *l1sram_alloc(size_t size)
-	unsigned flags;
 	void *addr;
@@ -569,7 +569,7 @@ void *l1sram_alloc(size_t size)
 void *l1sram_alloc_max(size_t *psize)
-	unsigned flags;
 	void *addr;
@@ -587,7 +587,7 @@ void *l1sram_alloc_max(size_t *psize)
 /* L1 Scratchpad memory free function */
 int l1sram_free(const void *addr)
-	unsigned flags;
 	int ret;
@@ -605,7 +605,7 @@ int l1sram_free(const void *addr)
 void *l2_sram_alloc(size_t size)
 #if L2_LENGTH != 0
-	unsigned flags;
 	void *addr;
@@ -641,7 +641,7 @@ EXPORT_SYMBOL(l2_sram_zalloc);
 int l2_sram_free(const void *addr)
 #if L2_LENGTH != 0
-	unsigned flags;
 	int ret;
BtrLinux
Privacy Overview
