bfa: remove useless return variables
Author: Peter Senna Tschudin <peter.senna@gmail.com>
This patch remove variables that are initialized with a constant,
are never updated, and are only used as parameter of return.
Return the constant instead of using a variable.
Verified by compilation only.
The coccinelle script that find and fixes this issue is:
type T;
constant C;
identifier ret;
- T ret = C;
... when != ret
    when strict
return
- ret
+ C
Signed-off-by: Peter Senna Tschudin
Acked-by: Sudarsana Kalluru
Signed-off-by: Christoph Hellwig
 drivers/scsi/bfa/bfad_bsg.c | 10 ++++------
 1 file changed, 4 insertions(+), 6 deletions(-)
diff --git a/drivers/scsi/bfa/bfad_bsg.c b/drivers/scsi/bfa/bfad_bsg.c
index 65f3e74..023b9d4 100644
--- a/drivers/scsi/bfa/bfad_bsg.c
+++ b/drivers/scsi/bfa/bfad_bsg.c
@@ -26,7 +26,6 @@ int
 bfad_iocmd_ioc_enable(struct bfad_s *bfad, void *cmd)
 	struct bfa_bsg_gen_s *iocmd = (struct bfa_bsg_gen_s *)cmd;
-	int	rc = 0;
 	unsigned long	flags;
 	spin_lock_irqsave(&bfad->bfad_lock, flags);
@@ -34,7 +33,7 @@ bfad_iocmd_ioc_enable(struct bfad_s *bfad, void *cmd)
 	if (!bfa_ioc_is_disabled(&bfad->bfa.ioc)) {
 		spin_unlock_irqrestore(&bfad->bfad_lock, flags);
 		iocmd->status = BFA_STATUS_OK;
-		return rc;
+		return 0;
 	init_completion(&bfad->enable_comp);
@@ -43,21 +42,20 @@ bfad_iocmd_ioc_enable(struct bfad_s *bfad, void *cmd)
 	wait_for_completion(&bfad->enable_comp);
-	return rc;
+	return 0;
 int
 bfad_iocmd_ioc_disable(struct bfad_s *bfad, void *cmd)
-	int	rc = 0;
 	if (bfa_ioc_is_disabled(&bfad->bfa.ioc)) {
-		return rc;
+		return 0;
 	if (bfad->disable_active) {
@@ -74,7 +72,7 @@ bfad_iocmd_ioc_disable(struct bfad_s *bfad, void *cmd)
 	bfad->disable_active = BFA_FALSE;
-	return rc;
+	return 0;
 static int
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
