avr: Cleanup genirq namespace
Author: Thomas Gleixner <tglx@linutronix.de>
Scripted conversion to new function names with coccinelle.
Signed-off-by: Thomas Gleixner
Cc: Hans-Christian Egtvedt
 arch/avr32/boards/atngw100/mrmt.c  |  2 +-
 arch/avr32/boards/atngw100/setup.c |  2 +-
 arch/avr32/mach-at32ap/extint.c    | 14 +++++++-------
 arch/avr32/mach-at32ap/intc.c      |  2 +-
 arch/avr32/mach-at32ap/pio.c       | 14 +++++++-------
 5 files changed, 17 insertions(+), 17 deletions(-)
diff --git a/arch/avr32/boards/atngw100/mrmt.c b/arch/avr32/boards/atngw100/mrmt.c
index 7919be3..f914319 100644
--- a/arch/avr32/boards/atngw100/mrmt.c
+++ b/arch/avr32/boards/atngw100/mrmt.c
@@ -301,7 +301,7 @@ static int __init mrmt1_init(void)
 	/* Select the Touchscreen interrupt pin mode */
 	at32_select_periph( GPIO_PIOB_BASE, 1 << (PB_EXTINT_BASE+TS_IRQ),
 			GPIO_PERIPH_A, AT32_GPIOF_DEGLITCH);
-	set_irq_type( AT32_EXTINT(TS_IRQ), IRQ_TYPE_EDGE_FALLING );
+	irq_set_irq_type(AT32_EXTINT(TS_IRQ), IRQ_TYPE_EDGE_FALLING);
 	at32_spi_setup_slaves(0,spi01_board_info,ARRAY_SIZE(spi01_board_info));
 	spi_register_board_info(spi01_board_info,ARRAY_SIZE(spi01_board_info));
 #endif
diff --git a/arch/avr32/boards/atngw100/setup.c b/arch/avr32/boards/atngw100/setup.c
index 659d119..fafed4c 100644
--- a/arch/avr32/boards/atngw100/setup.c
+++ b/arch/avr32/boards/atngw100/setup.c
@@ -322,6 +322,6 @@ static int __init atngw100_arch_init(void)
 	/* set_irq_type() after the arch_initcall for EIC has run, and
 	 * before the I2C subsystem could try using this IRQ.
-	return set_irq_type(AT32_EXTINT(3), IRQ_TYPE_EDGE_FALLING);
+	return irq_set_irq_type(AT32_EXTINT(3), IRQ_TYPE_EDGE_FALLING);
 arch_initcall(atngw100_arch_init);
diff --git a/arch/avr32/mach-at32ap/extint.c b/arch/avr32/mach-at32ap/extint.c
index bf3b2c5..23126aa 100644
--- a/arch/avr32/mach-at32ap/extint.c
+++ b/arch/avr32/mach-at32ap/extint.c
@@ -134,9 +134,9 @@ static int eic_set_irq_type(struct irq_chip *d, unsigned int flow_type)
 		if (flow_type & (IRQ_TYPE_LEVEL_LOW | IRQ_TYPE_LEVEL_HIGH)) {
 			flow_type |= IRQ_LEVEL;
-			__set_irq_handler_unlocked(irq, handle_level_irq);
+			__irq_set_handler_locked(irq, handle_level_irq);
 		} else
-			__set_irq_handler_unlocked(irq, handle_edge_irq);
+			__irq_set_handler_locked(irq, handle_edge_irq);
 		desc->status &= ~(IRQ_TYPE_SENSE_MASK | IRQ_LEVEL);
 		desc->status |= flow_type;
@@ -155,7 +155,7 @@ static struct irq_chip eic_chip = {
 static void demux_eic_irq(unsigned int irq, struct irq_desc *desc)
-	struct eic *eic = get_irq_desc_data(desc);
+	struct eic *eic = irq_desc_get_handler_data(desc);
 	unsigned long status, pending;
 	unsigned int i;
@@ -235,13 +235,13 @@ static int __init eic_probe(struct platform_device *pdev)
 	eic->chip = &eic_chip;
 	for (i = 0; i < nr_of_irqs; i++) {
-		set_irq_chip_and_handler(eic->first_irq + i, &eic_chip,
+		irq_set_chip_and_handler(eic->first_irq + i, &eic_chip,
 					 handle_level_irq);
-		set_irq_chip_data(eic->first_irq + i, eic);
+		irq_set_chip_data(eic->first_irq + i, eic);
-	set_irq_chained_handler(int_irq, demux_eic_irq);
-	set_irq_data(int_irq, eic);
+	irq_set_chained_handler(int_irq, demux_eic_irq);
+	irq_set_handler_data(int_irq, eic);
 	if (pdev->id == 0) {
 		nmi_eic = eic;
diff --git a/arch/avr32/mach-at32ap/intc.c b/arch/avr32/mach-at32ap/intc.c
index d9270d6..21ce35f 100644
--- a/arch/avr32/mach-at32ap/intc.c
+++ b/arch/avr32/mach-at32ap/intc.c
@@ -126,7 +126,7 @@ void __init init_IRQ(void)
 		intc_writel(&intc0, INTPR0 + 4 * i, offset);
 		readback = intc_readl(&intc0, INTPR0 + 4 * i);
 		if (readback == offset)
-			set_irq_chip_and_handler(i, &intc0.chip,
+			irq_set_chip_and_handler(i, &intc0.chip,
 						 handle_simple_irq);
diff --git a/arch/avr32/mach-at32ap/pio.c b/arch/avr32/mach-at32ap/pio.c
index 9b121d6..3753410 100644
--- a/arch/avr32/mach-at32ap/pio.c
+++ b/arch/avr32/mach-at32ap/pio.c
@@ -285,7 +285,7 @@ static void gpio_irq_handler(unsigned irq, struct irq_desc *desc)
 	struct pio_device	*pio = get_irq_desc_chip_data(desc);
 	unsigned		gpio_irq;
-	gpio_irq = (unsigned) get_irq_data(irq);
+	gpio_irq = (unsigned) irq_get_handler_data(irq);
 	for (;;) {
 		u32		isr;
@@ -310,16 +310,16 @@ gpio_irq_setup(struct pio_device *pio, int irq, int gpio_irq)
 	unsigned	i;
-	set_irq_chip_data(irq, pio);
-	set_irq_data(irq, (void *) gpio_irq);
+	irq_set_chip_data(irq, pio);
+	irq_set_handler_data(irq, (void *)gpio_irq);
 	for (i = 0; i < 32; i++, gpio_irq++) {
-		set_irq_chip_data(gpio_irq, pio);
-		set_irq_chip_and_handler(gpio_irq, &gpio_irqchip,
-				handle_simple_irq);
+		irq_set_chip_data(gpio_irq, pio);
+		irq_set_chip_and_handler(gpio_irq, &gpio_irqchip,
+					 handle_simple_irq);
-	set_irq_chained_handler(irq, gpio_irq_handler);
+	irq_set_chained_handler(irq, gpio_irq_handler);
BtrLinux
Privacy Overview
