atmel: Remove typedef atmel_priv_ioctl
Author: Himangi Saraogi <himangi774@gmail.com>
The Linux kernel coding style guidelines suggest not using typedefs
for structure types. This patch gets rid of the typedef for
atmel_priv_ioctl.
The following Coccinelle semantic patch detects the case:
@tn@
identifier i;
type td;
-typedef
struct i { ... }
-td
type tn.td;
identifier tn.i;
-td
+ struct i
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Signed-off-by: David S. Miller
drivers/net/wireless/atmel.c | 8 ++++----
1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/net/wireless/atmel.c b/drivers/net/wireless/atmel.c
index 1fe41af..9183f1c 100644
--- a/drivers/net/wireless/atmel.c
+++ b/drivers/net/wireless/atmel.c
@@ -2598,11 +2598,11 @@ static const iw_handler atmel_private_handler[] =
NULL, /* SIOCIWFIRSTPRIV */
-typedef struct atmel_priv_ioctl {
+struct atmel_priv_ioctl {
char id[32];
unsigned char __user *data;
unsigned short len;
-} atmel_priv_ioctl;
#define ATMELFWL SIOCIWFIRSTPRIV
#define ATMELIDIFC ATMELFWL + 1
@@ -2615,7 +2615,7 @@ static const struct iw_priv_args atmel_private_args[] = {
.cmd = ATMELFWL,
.set_args = IW_PRIV_TYPE_BYTE
| IW_PRIV_SIZE_FIXED
- | sizeof (atmel_priv_ioctl),
+ | sizeof(struct atmel_priv_ioctl),
.get_args = IW_PRIV_TYPE_NONE,
.name = "atmelfwl"
@@ -2645,7 +2645,7 @@ static int atmel_ioctl(struct net_device *dev, struct ifreq *rq, int cmd)
int i, rc = 0;
struct atmel_private *priv = netdev_priv(dev);
- atmel_priv_ioctl com;
+ struct atmel_priv_ioctl com;
struct iwreq *wrq = (struct iwreq *) rq;
unsigned char *new_firmware;
char domain[REGDOMAINSZ + 1]; |
char id[32];
unsigned short len;
.cmd = ATMELFWL,
| IW_PRIV_SIZE_FIXED
.name = "atmelfwl"
int i, rc = 0;
