atm: use msecs_to_jiffies for conversions
Author: Nicholas Mc Guire <hofrat@osadl.org>
API compliance scanning with coccinelle flagged:
./drivers/atm/iphase.c:2621:4-20:
        WARNING: timeout (50) seems HZ dependent
Numeric constants passed to schedule_timeout() make the effective
timeout HZ dependent which does not seem intended.
Fixed up by converting the constant to jiffies with msecs_to_jiffies()
As this driver was introduced in the early 2.3 series it is most
likely assuming HZ=100 so the constant 50 is converted to 500ms.
Signed-off-by: Nicholas Mc Guire
Signed-off-by: David S. Miller
 drivers/atm/iphase.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/atm/iphase.c b/drivers/atm/iphase.c
index 924f8e2..65e6590 100644
--- a/drivers/atm/iphase.c
+++ b/drivers/atm/iphase.c
@@ -2618,7 +2618,7 @@ static void ia_close(struct atm_vcc *vcc)
         if (vcc->qos.txtp.traffic_class != ATM_NONE) {
            iadev->close_pending++;
 	   prepare_to_wait(&iadev->timeout_wait, &wait, TASK_UNINTERRUPTIBLE);
-	   schedule_timeout(50);
+	   schedule_timeout(msecs_to_jiffies(500));
 	   finish_wait(&iadev->timeout_wait, &wait);
            spin_lock_irqsave(&iadev->tx_lock, flags);
            while((skb = skb_dequeue(&iadev->tx_backlog))) {
BtrLinux
Privacy Overview
