atm: idt77252: Remove redundant error check
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Remove double checks, convert printk to pr_warn, and move the call to
pr_warn to the first check. The simplified version of the coccinelle
semantic patch that find this issue is as follows:
expression E; identifier pr; expression list es;
while(...){
-       if (E) break;
+       if (E){
+               pr(es);
+               break;
- if(E) pr(es);
Tested by compilation only.
Signed-off-by: Peter Senna Tschudin
Signed-off-by: David S. Miller
 drivers/atm/idt77252.c | 8 ++++----
 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/atm/idt77252.c b/drivers/atm/idt77252.c
index 1bdf104..b621f56 100644
--- a/drivers/atm/idt77252.c
+++ b/drivers/atm/idt77252.c
@@ -2551,12 +2551,12 @@ done:
 		timeout = 5 * 1000;
 		while (atomic_read(&vc->scq->used) > 0) {
 			timeout = msleep_interruptible(timeout);
-			if (!timeout)
+			if (!timeout) {
+				pr_warn("%s: SCQ drain timeout: %u used\n",
+					card->name, atomic_read(&vc->scq->used));
 				break;
-		if (!timeout)
-			printk("%s: SCQ drain timeout: %u used\n",
-			       card->name, atomic_read(&vc->scq->used));
 		writel(TCMDQ_HALT | vc->index, SAR_REG_TCMDQ);
 		clear_scd(card, vc->scq, vc->class);
BtrLinux
Privacy Overview
