atm: idt77105: Use setup_timer
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
Use the timer API function setup_timer instead of structure field
assignments to initialize a timer.
A simplified version of the Coccinelle semantic patch that performs
this transformation is as follows:
@change@
expression e1, e2, a;
-init_timer(&e1);
+setup_timer(&e1, a, 0UL);
... when != a = e2
-e1.function = a;
Signed-off-by: Vaishali Thakkar
Signed-off-by: David S. Miller
 drivers/atm/idt77105.c | 6 ++----
 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/atm/idt77105.c b/drivers/atm/idt77105.c
index 909c95b..feb023d 100644
--- a/drivers/atm/idt77105.c
+++ b/drivers/atm/idt77105.c
@@ -306,14 +306,12 @@ static int idt77105_start(struct atm_dev *dev)
 	if (start_timer) {
 		start_timer = 0;
-		init_timer(&stats_timer);
+		setup_timer(&stats_timer, idt77105_stats_timer_func, 0UL);
 		stats_timer.expires = jiffies+IDT77105_STATS_TIMER_PERIOD;
-		stats_timer.function = idt77105_stats_timer_func;
 		add_timer(&stats_timer);
-		init_timer(&restart_timer);
+		setup_timer(&restart_timer, idt77105_restart_timer_func, 0UL);
 		restart_timer.expires = jiffies+IDT77105_RESTART_TIMER_PERIOD;
-		restart_timer.function = idt77105_restart_timer_func;
 		add_timer(&restart_timer);
 	spin_unlock_irqrestore(&idt77105_priv_lock, flags);
BtrLinux
Privacy Overview
