atm: horizon: Use setup_timer
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Convert a call to init_timer and accompanying intializations of
the timer's data and function fields to a call to setup_timer.
The Coccinelle semantic patch that fixes this problem is
as follows:
expression t,d,f,e1;
identifier x1;
statement S1;
-t.data = d;
-t.function = f;
-init_timer(&t);
+setup_timer(&t,f,d);
-init_timer_on_stack(&t);
+setup_timer_on_stack(&t,f,d);
<... when != S1
t.x1 = e1;
Signed-off-by: Amitoj Kaur Chawla
Signed-off-by: David S. Miller
 drivers/atm/horizon.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/atm/horizon.c b/drivers/atm/horizon.c
index 527bbd5..5fc81e2 100644
--- a/drivers/atm/horizon.c
+++ b/drivers/atm/horizon.c
@@ -2795,9 +2795,7 @@ static int hrz_probe(struct pci_dev *pci_dev,
 	dev->atm_dev->ci_range.vpi_bits = vpi_bits;
 	dev->atm_dev->ci_range.vci_bits = 10-vpi_bits;
-	init_timer(&dev->housekeeping);
-	dev->housekeeping.function = do_housekeeping;
-	dev->housekeeping.data = (unsigned long) dev;
+	setup_timer(&dev->housekeeping, do_housekeeping, (unsigned long) dev);
 	mod_timer(&dev->housekeeping, jiffies);
 out:
BtrLinux
Privacy Overview
