atl1e: Use setup_timer
Author: Julia Lawall <julia.lawall@lip6.fr>
Convert a call to init_timer and accompanying intializations of
the timer's data and function fields to a call to setup_timer.
A simplified version of the semantic match that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
expression t,f,d;
-init_timer(&t);
+setup_timer(&t,f,d);
-t.function = f;
-t.data = d;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/ethernet/atheros/atl1e/atl1e_main.c | 5 ++---
 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/net/ethernet/atheros/atl1e/atl1e_main.c b/drivers/net/ethernet/atheros/atl1e/atl1e_main.c
index 2326579..c88abf5 100644
--- a/drivers/net/ethernet/atheros/atl1e/atl1e_main.c
+++ b/drivers/net/ethernet/atheros/atl1e/atl1e_main.c
@@ -2373,9 +2373,8 @@ static int atl1e_probe(struct pci_dev *pdev, const struct pci_device_id *ent)
 	netif_napi_add(netdev, &adapter->napi, atl1e_clean, 64);
-	init_timer(&adapter->phy_config_timer);
-	adapter->phy_config_timer.function = atl1e_phy_config;
-	adapter->phy_config_timer.data = (unsigned long) adapter;
+	setup_timer(&adapter->phy_config_timer, atl1e_phy_config,
+		    (unsigned long)adapter);
 	/* get user settings */
 	atl1e_check_options(adapter);
BtrLinux
Privacy Overview
