atheros: atlx: Use setup_timer
Author: Julia Lawall <julia.lawall@lip6.fr>
Convert a call to init_timer and accompanying intializations of
the timer's data and function fields to a call to setup_timer.
A simplified version of the semantic match that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
expression t,f,d;
-init_timer(&t);
+setup_timer(&t,f,d);
-t.function = f;
-t.data = d;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/ethernet/atheros/atlx/atl2.c | 10 ++++------
 1 file changed, 4 insertions(+), 6 deletions(-)
diff --git a/drivers/net/ethernet/atheros/atlx/atl2.c b/drivers/net/ethernet/atheros/atlx/atl2.c
index 84a09e8..482a7ca 100644
--- a/drivers/net/ethernet/atheros/atlx/atl2.c
+++ b/drivers/net/ethernet/atheros/atlx/atl2.c
@@ -1436,13 +1436,11 @@ static int atl2_probe(struct pci_dev *pdev, const struct pci_device_id *ent)
 	atl2_check_options(adapter);
-	init_timer(&adapter->watchdog_timer);
-	adapter->watchdog_timer.function = atl2_watchdog;
-	adapter->watchdog_timer.data = (unsigned long) adapter;
+	setup_timer(&adapter->watchdog_timer, atl2_watchdog,
+		    (unsigned long)adapter);
-	init_timer(&adapter->phy_config_timer);
-	adapter->phy_config_timer.function = atl2_phy_config;
-	adapter->phy_config_timer.data = (unsigned long) adapter;
+	setup_timer(&adapter->phy_config_timer, atl2_phy_config,
 	INIT_WORK(&adapter->reset_task, atl2_reset_task);
 	INIT_WORK(&adapter->link_chg_task, atl2_link_chg_task);
BtrLinux
Privacy Overview
