ath9k: use ether_addr_equal_64bits
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Ether_addr_equal_64bits is more efficient than ether_addr_equal, and can be
used when each argument is an array within a structure that contains at
least two bytes of data beyond the array.
The structures involved are:
ieee80211_hdr defined in include/linux/ieee80211.h
ath_common defined in drivers/net/wireless/ath/ath.h
This was done using Coccinelle (http://coccinelle.lip6.fr/).
Signed-off-by: Julia Lawall
Signed-off-by: John W. Linville
 drivers/net/wireless/ath/ath9k/htc_drv_txrx.c | 2 +-
 drivers/net/wireless/ath/ath9k/recv.c         | 2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/net/wireless/ath/ath9k/htc_drv_txrx.c b/drivers/net/wireless/ath/ath9k/htc_drv_txrx.c
index c028df7..b41e008 100644
--- a/drivers/net/wireless/ath/ath9k/htc_drv_txrx.c
+++ b/drivers/net/wireless/ath/ath9k/htc_drv_txrx.c
@@ -1077,7 +1077,7 @@ static bool ath9k_rx_prepare(struct ath9k_htc_priv *priv,
 	if (ieee80211_is_beacon(hdr->frame_control) &&
 	    !is_zero_ether_addr(common->curbssid) &&
-	    ether_addr_equal(hdr->addr3, common->curbssid)) {
+	    ether_addr_equal_64bits(hdr->addr3, common->curbssid)) {
 		s8 rssi = rxbuf->rxstatus.rs_rssi;
 		if (likely(last_rssi != ATH_RSSI_DUMMY_MARKER))
diff --git a/drivers/net/wireless/ath/ath9k/recv.c b/drivers/net/wireless/ath/ath9k/recv.c
index 470e1c0..01c41c6 100644
--- a/drivers/net/wireless/ath/ath9k/recv.c
+++ b/drivers/net/wireless/ath/ath9k/recv.c
@@ -982,7 +982,7 @@ static bool ath9k_is_mybeacon(struct ath_softc *sc, struct ieee80211_hdr *hdr)
 	if (ieee80211_is_beacon(hdr->frame_control)) {
 		RX_STAT_INC(rx_beacons);
 		if (!is_zero_ether_addr(common->curbssid) &&
 			return true;
BtrLinux
Privacy Overview
