ath9k: Delete an unnecessary check before the function call “relay_close”
Author: Markus Elfring <elfring@users.sourceforge.net>
The relay_close() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Kalle Valo
 drivers/net/wireless/ath/ath9k/common-spectral.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/wireless/ath/ath9k/common-spectral.c b/drivers/net/wireless/ath/ath9k/common-spectral.c
index ec93ddf..5cee231 100644
--- a/drivers/net/wireless/ath/ath9k/common-spectral.c
+++ b/drivers/net/wireless/ath/ath9k/common-spectral.c
@@ -582,7 +582,7 @@ static struct rchan_callbacks rfs_spec_scan_cb = {
 void ath9k_cmn_spectral_deinit_debug(struct ath_spec_scan_priv *spec_priv)
-	if (config_enabled(CONFIG_ATH9K_DEBUGFS) && spec_priv->rfs_chan_spec_scan) {
+	if (config_enabled(CONFIG_ATH9K_DEBUGFS)) {
 		relay_close(spec_priv->rfs_chan_spec_scan);
 		spec_priv->rfs_chan_spec_scan = NULL;
BtrLinux
Privacy Overview
