ath6kl: add missing of_node_put
Author: Julia Lawall <julia.lawall@lip6.fr>
for_each_compatible_node performs an of_node_get on each iteration, so
a break out of the loop requires an of_node_put.
A simplified version of the semantic patch that fixes this problem is as
follows (http://coccinelle.lip6.fr):
expression e;
local idexpression n;
 for_each_compatible_node(n,...) {
   ... when != of_node_put(n)
       when != e = n
   return n;
+  of_node_put(n);
?  return ...;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/wireless/ath/ath6kl/init.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/net/wireless/ath/ath6kl/init.c b/drivers/net/wireless/ath/ath6kl/init.c
index 6e473fa..12241b1 100644
--- a/drivers/net/wireless/ath/ath6kl/init.c
+++ b/drivers/net/wireless/ath/ath6kl/init.c
@@ -715,6 +715,7 @@ static bool check_device_tree(struct ath6kl *ar)
 				   board_filename, ret);
 			continue;
+		of_node_put(node);
 		return true;
 	return false;
BtrLinux
Privacy Overview
