ath5k: use ether_addr_equal_64bits
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Ether_addr_equal_64bits is more efficient than ether_addr_equal, and can be
used when each argument is an array within a structure that contains at
least two bytes of data beyond the array.
The structures involved are:
ieee80211_mgmt defined in include/linux/ieee80211.h and
ath_common defined in drivers/net/wireless/ath/ath.h
This was done using Coccinelle (http://coccinelle.lip6.fr/).
Signed-off-by: Julia Lawall
Signed-off-by: John W. Linville
 drivers/net/wireless/ath/ath5k/base.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/net/wireless/ath/ath5k/base.c b/drivers/net/wireless/ath/ath5k/base.c
index 69f58b0..6396ad4 100644
--- a/drivers/net/wireless/ath/ath5k/base.c
+++ b/drivers/net/wireless/ath/ath5k/base.c
@@ -1245,7 +1245,7 @@ ath5k_check_ibss_tsf(struct ath5k_hw *ah, struct sk_buff *skb,
 	if (ieee80211_is_beacon(mgmt->frame_control) &&
 	    le16_to_cpu(mgmt->u.beacon.capab_info) & WLAN_CAPABILITY_IBSS &&
-	    ether_addr_equal(mgmt->bssid, common->curbssid)) {
+	    ether_addr_equal_64bits(mgmt->bssid, common->curbssid)) {
 		 * Received an IBSS beacon with the same BSSID. Hardware *must*
 		 * have updated the local TSF. We have to work around various
@@ -1309,7 +1309,7 @@ ath5k_update_beacon_rssi(struct ath5k_hw *ah, struct sk_buff *skb, int rssi)
 	/* only beacons from our BSSID */
 	if (!ieee80211_is_beacon(mgmt->frame_control) ||
-	    !ether_addr_equal(mgmt->bssid, common->curbssid))
+	    !ether_addr_equal_64bits(mgmt->bssid, common->curbssid))
 		return;
 	ewma_add(&ah->ah_beacon_rssi_avg, rssi);
BtrLinux
Privacy Overview
