ath10k: delete unnecessary checks before the function call “release_firmware”
Author: Markus Elfring <elfring@users.sourceforge.net>
The release_firmware() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Kalle Valo
 drivers/net/wireless/ath/ath10k/core.c | 8 ++++----
 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/net/wireless/ath/ath10k/core.c b/drivers/net/wireless/ath/ath10k/core.c
index 310e12b..c0e454b 100644
--- a/drivers/net/wireless/ath/ath10k/core.c
+++ b/drivers/net/wireless/ath/ath10k/core.c
@@ -436,16 +436,16 @@ static int ath10k_download_fw(struct ath10k *ar, enum ath10k_firmware_mode mode)
 static void ath10k_core_free_firmware_files(struct ath10k *ar)
-	if (ar->board && !IS_ERR(ar->board))
+	if (!IS_ERR(ar->board))
 		release_firmware(ar->board);
-	if (ar->otp && !IS_ERR(ar->otp))
+	if (!IS_ERR(ar->otp))
 		release_firmware(ar->otp);
-	if (ar->firmware && !IS_ERR(ar->firmware))
+	if (!IS_ERR(ar->firmware))
 		release_firmware(ar->firmware);
-	if (ar->cal_file && !IS_ERR(ar->cal_file))
+	if (!IS_ERR(ar->cal_file))
 		release_firmware(ar->cal_file);
 	ar->board = NULL;
