ataflop: adjust NULL test
dtp is derefenced on the lines above the test !dtp, and so it cannot be
NULL at this point.
A simplified version of the semantic match that finds this problem is as
follows: (http://www.emn.fr/x-info/coccinelle/)
@r@
expression x,E,E1;
identifier f,l;
position p1,p2;
*x@p1->f = E1;
... when != x = E
    when != goto l;
*x@p2 == NULL
*x@p2 != NULL
Signed-off-by: Julia Lawall
Signed-off-by: Tejun Heo
 drivers/block/ataflop.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/block/ataflop.c b/drivers/block/ataflop.c
index f5e7180..3ff0294 100644
--- a/drivers/block/ataflop.c
+++ b/drivers/block/ataflop.c
@@ -1627,7 +1627,7 @@ static int fd_ioctl(struct block_device *bdev, fmode_t mode,
 				drive, dtp->blocks, dtp->spt, dtp->stretch);
 		/* sanity check */
-		if (!dtp || setprm.track != dtp->blocks/dtp->spt/2 ||
+		if (setprm.track != dtp->blocks/dtp->spt/2 ||
 		    setprm.head != 2) {
 			redo_fd_request();
 			return -EINVAL;
BtrLinux
Privacy Overview
