ata: remove unnecessary code
Author: Greg Dietsche <Gregory.Dietsche@cuw.edu>
Compile tested.
remove unnecessary code that matches this coccinelle pattern
	if (...)
		return ret;
	return ret;
Signed-off-by: Greg Dietsche
Signed-off-by: Jeff Garzik
 drivers/ata/pata_acpi.c | 8 +-------
 1 file changed, 1 insertion(+), 7 deletions(-)
diff --git a/drivers/ata/pata_acpi.c b/drivers/ata/pata_acpi.c
index 91949d9..54145ed 100644
--- a/drivers/ata/pata_acpi.c
+++ b/drivers/ata/pata_acpi.c
@@ -195,8 +195,6 @@ static int pacpi_port_start(struct ata_port *ap)
 	struct pci_dev *pdev = to_pci_dev(ap->host->dev);
 	struct pata_acpi *acpi;
-	int ret;
 	if (ap->acpi_handle == NULL)
 		return -ENODEV;
@@ -205,11 +203,7 @@ static int pacpi_port_start(struct ata_port *ap)
 		return -ENOMEM;
 	acpi->mask[0] = pacpi_discover_modes(ap, &ap->link.device[0]);
 	acpi->mask[1] = pacpi_discover_modes(ap, &ap->link.device[1]);
-	ret = ata_bmdma_port_start(ap);
-	if (ret < 0)
-		return ret;
-	return ret;
+	return ata_bmdma_port_start(ap);
 static struct scsi_host_template pacpi_sht = {
BtrLinux
Privacy Overview
