ASoC: zx: fix simple_return.cocci warnings
Author: kbuild test robot <fengguang.wu@intel.com>
sound/soc/zte/zx296702-spdif.c:191:1-4: WARNING: end returns can be simpified
Simplify a trivial if-return sequence. Possibly combine with a
preceding function call.
Generated by: scripts/coccinelle/misc/simple_return.cocci
Signed-off-by: Fengguang Wu
Signed-off-by: Mark Brown
sound/soc/zte/zx296702-spdif.c | 6 +-----
1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/sound/soc/zte/zx296702-spdif.c b/sound/soc/zte/zx296702-spdif.c
index 27d940c..4a93bca 100644
--- a/sound/soc/zte/zx296702-spdif.c
+++ b/sound/soc/zte/zx296702-spdif.c
@@ -188,11 +188,7 @@ static int zx_spdif_hw_params(struct snd_pcm_substream *substream,
ret = zx_spdif_chanstats(zx_spdif->reg_base, rate);
if (ret)
return ret;
- ret = clk_set_rate(spdif->dai_clk, rate * ch_num * ZX_SPDIF_CLK_RAT);
- if (ret)
- return ret;
- return 0;
+ return clk_set_rate(spdif->dai_clk, rate * ch_num * ZX_SPDIF_CLK_RAT);
static void zx_spdif_cfg_tx(void __iomem *base, int on) |
if (ret)
return ret;
- if (ret)
- return ret;
- return 0;
