ASoC: wm8753: Replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGE
Author: Lars-Peter Clausen <lars@metafoo.de>
DECLARE_TLV_DB_RANGE() has the advantage over using TLV_DB_RANGE_HEAD()
that it automatically calculates the number of items in the TLV and is
hence less prone to manual error.
Generate using the following coccinelle script
declarer name DECLARE_TLV_DB_RANGE;
identifier tlv;
constant x;
-unsigned int tlv[] = {
-	TLV_DB_RANGE_HEAD(x),
+DECLARE_TLV_DB_RANGE(tlv,
Signed-off-by: Lars-Peter Clausen
Signed-off-by: Mark Brown
 sound/soc/codecs/wm8753.c | 7 +++----
 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/sound/soc/codecs/wm8753.c b/sound/soc/codecs/wm8753.c
index feb2997a..f588341 100644
--- a/sound/soc/codecs/wm8753.c
+++ b/sound/soc/codecs/wm8753.c
@@ -276,12 +276,11 @@ static const DECLARE_TLV_DB_SCALE(rec_mix_tlv, -1500, 300, 0);
 static const DECLARE_TLV_DB_SCALE(mic_preamp_tlv, 1200, 600, 0);
 static const DECLARE_TLV_DB_SCALE(adc_tlv, -9750, 50, 1);
 static const DECLARE_TLV_DB_SCALE(dac_tlv, -12750, 50, 1);
-static const unsigned int out_tlv[] = {
-	TLV_DB_RANGE_HEAD(2),
+static const DECLARE_TLV_DB_RANGE(out_tlv,
 	/* 0000000 - 0101111 = "Analogue mute" */
 	0, 48, TLV_DB_SCALE_ITEM(-25500, 0, 0),
-	48, 127, TLV_DB_SCALE_ITEM(-7300, 100, 0),
+	48, 127, TLV_DB_SCALE_ITEM(-7300, 100, 0)
 static const DECLARE_TLV_DB_SCALE(mix_tlv, -1500, 300, 0);
 static const DECLARE_TLV_DB_SCALE(voice_mix_tlv, -1200, 300, 0);
 static const DECLARE_TLV_DB_SCALE(pga_tlv, -1725, 75, 0);
BtrLinux
Privacy Overview
