ASoC: wm5102: Use put_unaligned_be16
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
This patch introduces the use of function put_unaligned_be16.
This is done using Coccinelle and semantic patch used is as follows:
@a@
typedef u16, __be16, uint16_t;
{u16,__be16,uint16_t} e16;
identifier tmp;
expression ptr;
expression y,e;
type T;
- tmp = cpu_to_be16(y);
<+... when != tmp
- memcpy(ptr, (T)&tmp, \(2\|sizeof(u16)\|sizeof(__be16)\|sizeof(uint16_t)\|sizeof(e16)\));
+ put_unaligned_be16(y,ptr);
- memcpy(ptr, (T)&tmp, ...);
? tmp = e
@@ type T; identifier a.tmp; @@
- T tmp;
...when != tmp
Signed-off-by: Vaishali Thakkar
Acked-by: Charles Keepax
Changes Since v2:
   Make the patch compatible for current code
 sound/soc/codecs/wm5102.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
Signed-off-by: Mark Brown
diff --git a/sound/soc/codecs/wm5102.c b/sound/soc/codecs/wm5102.c
index f439ae0..7dbac8a 100644
--- a/sound/soc/codecs/wm5102.c
+++ b/sound/soc/codecs/wm5102.c
@@ -28,6 +28,7 @@
 #include <linux/mfd/arizona/core.h>
 #include <linux/mfd/arizona/registers.h>
+#include <asm/unaligned.h>
 #include "arizona.h"
 #include "wm5102.h"
@@ -617,11 +618,10 @@ static int wm5102_out_comp_coeff_get(struct snd_kcontrol *kcontrol,
 	struct snd_soc_codec *codec = snd_soc_kcontrol_codec(kcontrol);
 	struct arizona *arizona = dev_get_drvdata(codec->dev->parent);
-	uint16_t data;
 	mutex_lock(&arizona->dac_comp_lock);
-	data = cpu_to_be16(arizona->dac_comp_coeff);
-	memcpy(ucontrol->value.bytes.data, &data, sizeof(data));
+	put_unaligned_be16(arizona->dac_comp_coeff,
+			   ucontrol->value.bytes.data);
 	mutex_unlock(&arizona->dac_comp_lock);
 	return 0;
BtrLinux
Privacy Overview
