ASoC: wm0010: Remove spurious missing IRQF_ONESHOT
Author: Axel Lin <axel.lin@ingics.com>
This reverts 58d468328646 ("ASoC: wm0010: Add missing IRQF_ONESHOT").
The coccinelle warnings is false positive because the original code does
set IRQF_ONESHOT by "trigger |= IRQF_ONESHOT;".
Signed-off-by: Axel Lin
Acked-by: Charles Keepax
Signed-off-by: Mark Brown
 sound/soc/codecs/wm0010.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/sound/soc/codecs/wm0010.c b/sound/soc/codecs/wm0010.c
index e1da49f..f2c6ad4 100644
--- a/sound/soc/codecs/wm0010.c
+++ b/sound/soc/codecs/wm0010.c
@@ -953,7 +953,7 @@ static int wm0010_spi_probe(struct spi_device *spi)
 		trigger = IRQF_TRIGGER_FALLING;
-	ret = request_threaded_irq(irq, NULL, wm0010_irq, trigger | IRQF_ONESHOT,
+	ret = request_threaded_irq(irq, NULL, wm0010_irq, trigger,
 				   "wm0010", wm0010);
 	if (ret) {
 		dev_err(wm0010->dev, "Failed to request IRQ %d: %d\n",
BtrLinux
Privacy Overview
