ASoC: uda1380: Replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGE
Author: Lars-Peter Clausen <lars@metafoo.de>
DECLARE_TLV_DB_RANGE() has the advantage over using TLV_DB_RANGE_HEAD()
that it automatically calculates the number of items in the TLV and is
hence less prone to manual error.
Generate using the following coccinelle script
declarer name DECLARE_TLV_DB_RANGE;
identifier tlv;
constant x;
-unsigned int tlv[] = {
-	TLV_DB_RANGE_HEAD(x),
+DECLARE_TLV_DB_RANGE(tlv,
Signed-off-by: Lars-Peter Clausen
Signed-off-by: Mark Brown
 sound/soc/codecs/uda1380.c | 14 ++++++--------
 1 file changed, 6 insertions(+), 8 deletions(-)
diff --git a/sound/soc/codecs/uda1380.c b/sound/soc/codecs/uda1380.c
index 6e159f5..4b9b438 100644
--- a/sound/soc/codecs/uda1380.c
+++ b/sound/soc/codecs/uda1380.c
@@ -269,12 +269,11 @@ static DECLARE_TLV_DB_SCALE(amix_tlv, -4950, 150, 1);
  * from -66 dB in 0.5 dB steps (2 dB steps, really) and
  * from -52 dB in 0.25 dB steps
-static const unsigned int mvol_tlv[] = {
-	TLV_DB_RANGE_HEAD(3),
+static const DECLARE_TLV_DB_RANGE(mvol_tlv,
 	0, 15, TLV_DB_SCALE_ITEM(-8200, 100, 1),
 	16, 43, TLV_DB_SCALE_ITEM(-6600, 50, 0),
-	44, 252, TLV_DB_SCALE_ITEM(-5200, 25, 0),
+	44, 252, TLV_DB_SCALE_ITEM(-5200, 25, 0)
  * from -72 dB in 1.5 dB steps (6 dB steps really),
@@ -282,13 +281,12 @@ static const unsigned int mvol_tlv[] = {
  * from -60 dB in 0.5 dB steps (2 dB steps really) and
  * from -46 dB in 0.25 dB steps
-static const unsigned int vc_tlv[] = {
-	TLV_DB_RANGE_HEAD(4),
+static const DECLARE_TLV_DB_RANGE(vc_tlv,
 	0, 7, TLV_DB_SCALE_ITEM(-7800, 150, 1),
 	8, 15, TLV_DB_SCALE_ITEM(-6600, 75, 0),
 	16, 43, TLV_DB_SCALE_ITEM(-6000, 50, 0),
-	44, 228, TLV_DB_SCALE_ITEM(-4600, 25, 0),
+	44, 228, TLV_DB_SCALE_ITEM(-4600, 25, 0)
 /* from 0 to 6 dB in 2 dB steps if SPF mode != flat */
 static DECLARE_TLV_DB_SCALE(tr_tlv, 0, 200, 0);
BtrLinux
Privacy Overview
