ASoC: twl4030: Replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGE
Author: Lars-Peter Clausen <lars@metafoo.de>
DECLARE_TLV_DB_RANGE() has the advantage over using TLV_DB_RANGE_HEAD()
that it automatically calculates the number of items in the TLV and is
hence less prone to manual error.
Generate using the following coccinelle script
declarer name DECLARE_TLV_DB_RANGE;
identifier tlv;
constant x;
-unsigned int tlv[] = {
-	TLV_DB_RANGE_HEAD(x),
+DECLARE_TLV_DB_RANGE(tlv,
Signed-off-by: Lars-Peter Clausen
Acked-by: Peter Ujfalusi
Signed-off-by: Mark Brown
 sound/soc/codecs/twl4030.c | 7 +++----
 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/sound/soc/codecs/twl4030.c b/sound/soc/codecs/twl4030.c
index 90f5f04..2713e18 100644
--- a/sound/soc/codecs/twl4030.c
+++ b/sound/soc/codecs/twl4030.c
@@ -524,12 +524,11 @@ static const struct snd_kcontrol_new twl4030_dapm_abypassv_control =
 	SOC_DAPM_SINGLE("Switch", TWL4030_REG_VDL_APGA_CTL, 2, 1, 0);
 /* Digital bypass gain, mute instead of -30dB */
-static const unsigned int twl4030_dapm_dbypass_tlv[] = {
-	TLV_DB_RANGE_HEAD(3),
+static const DECLARE_TLV_DB_RANGE(twl4030_dapm_dbypass_tlv,
 	0, 1, TLV_DB_SCALE_ITEM(-3000, 600, 1),
 	2, 3, TLV_DB_SCALE_ITEM(-2400, 0, 0),
-	4, 7, TLV_DB_SCALE_ITEM(-1800, 600, 0),
+	4, 7, TLV_DB_SCALE_ITEM(-1800, 600, 0)
 /* Digital bypass left (TX1L -> RX2L) */
 static const struct snd_kcontrol_new twl4030_dapm_dbypassl_control =
BtrLinux
Privacy Overview
