ASoC: ssm2602: Replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGE
Author: Lars-Peter Clausen <lars@metafoo.de>
DECLARE_TLV_DB_RANGE() has the advantage over using TLV_DB_RANGE_HEAD()
that it automatically calculates the number of items in the TLV and is
hence less prone to manual error.
Generate using the following coccinelle script
declarer name DECLARE_TLV_DB_RANGE;
identifier tlv;
constant x;
-unsigned int tlv[] = {
-	TLV_DB_RANGE_HEAD(x),
+DECLARE_TLV_DB_RANGE(tlv,
Signed-off-by: Lars-Peter Clausen
Signed-off-by: Mark Brown
 sound/soc/codecs/ssm2602.c | 7 +++----
 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/sound/soc/codecs/ssm2602.c b/sound/soc/codecs/ssm2602.c
index 69a773a..4452fea 100644
--- a/sound/soc/codecs/ssm2602.c
+++ b/sound/soc/codecs/ssm2602.c
@@ -75,11 +75,10 @@ static const struct soc_enum ssm2602_enum[] = {
 			ssm2602_deemph),
-static const unsigned int ssm260x_outmix_tlv[] = {
-	TLV_DB_RANGE_HEAD(2),
+static const DECLARE_TLV_DB_RANGE(ssm260x_outmix_tlv,
 	0, 47, TLV_DB_SCALE_ITEM(TLV_DB_GAIN_MUTE, 0, 0),
-	48, 127, TLV_DB_SCALE_ITEM(-7400, 100, 0),
+	48, 127, TLV_DB_SCALE_ITEM(-7400, 100, 0)
 static const DECLARE_TLV_DB_SCALE(ssm260x_inpga_tlv, -3450, 150, 0);
 static const DECLARE_TLV_DB_SCALE(ssm260x_sidetone_tlv, -1500, 300, 0);
BtrLinux
Privacy Overview
