ASoC: ssm2518: Use a signed return type for ssm2518_lookup_mcs()
Author: Markus Elfring <elfring@users.sourceforge.net>
The return type "unsigned int" was used by the ssm2518_lookup_mcs()
function even though it will eventually return a negative error code.
Improve this implementation detail by deletion of the type modifier then.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Mark Brown
sound/soc/codecs/ssm2518.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/sound/soc/codecs/ssm2518.c b/sound/soc/codecs/ssm2518.c
index 86b81a6..e2e0bfa 100644
--- a/sound/soc/codecs/ssm2518.c
+++ b/sound/soc/codecs/ssm2518.c
@@ -309,7 +309,7 @@ static const struct snd_pcm_hw_constraint_list ssm2518_constraints_12288000 = {
.count = ARRAY_SIZE(ssm2518_rates_12288000),
-static unsigned int ssm2518_lookup_mcs(struct ssm2518 *ssm2518,
+static int ssm2518_lookup_mcs(struct ssm2518 *ssm2518,
unsigned int rate)
const unsigned int *sysclks = NULL; |
unsigned int rate)
