ASoC: sgtl5000: Replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGE
Author: Lars-Peter Clausen <lars@metafoo.de>
DECLARE_TLV_DB_RANGE() has the advantage over using TLV_DB_RANGE_HEAD()
that it automatically calculates the number of items in the TLV and is
hence less prone to manual error.
Generate using the following coccinelle script
declarer name DECLARE_TLV_DB_RANGE;
identifier tlv;
constant x;
-unsigned int tlv[] = {
-	TLV_DB_RANGE_HEAD(x),
+DECLARE_TLV_DB_RANGE(tlv,
Signed-off-by: Lars-Peter Clausen
Signed-off-by: Mark Brown
 sound/soc/codecs/sgtl5000.c | 7 +++----
 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/sound/soc/codecs/sgtl5000.c b/sound/soc/codecs/sgtl5000.c
index e673f6c..c59a687 100644
--- a/sound/soc/codecs/sgtl5000.c
+++ b/sound/soc/codecs/sgtl5000.c
@@ -406,11 +406,10 @@ static int dac_put_volsw(struct snd_kcontrol *kcontrol,
 static const DECLARE_TLV_DB_SCALE(capture_6db_attenuate, -600, 600, 0);
 /* tlv for mic gain, 0db 20db 30db 40db */
-static const unsigned int mic_gain_tlv[] = {
-	TLV_DB_RANGE_HEAD(2),
+static const DECLARE_TLV_DB_RANGE(mic_gain_tlv,
 	0, 0, TLV_DB_SCALE_ITEM(0, 0, 0),
-	1, 3, TLV_DB_SCALE_ITEM(2000, 1000, 0),
+	1, 3, TLV_DB_SCALE_ITEM(2000, 1000, 0)
 /* tlv for hp volume, -51.5db to 12.0db, step .5db */
 static const DECLARE_TLV_DB_SCALE(headphone_volume, -5150, 50, 0);
