ASoC: rsnd: fix usrcnt decrementing bug
Author: Andrzej Hajda <a.hajda@samsung.com>
Field usrcnt is unsigned so it cannot be lesser than zero.
The patch fixes the check, moves it to the beginning of the function
and changes return value to -EIO in case of usercnt error.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/unsigned_lesser_than_zero.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2038576
Signed-off-by: Andrzej Hajda
Acked-by: Kuninori Morimoto
Signed-off-by: Mark Brown
 sound/soc/sh/rcar/ssi.c | 27 ++++++++++++++-------------
 1 file changed, 14 insertions(+), 13 deletions(-)
diff --git a/sound/soc/sh/rcar/ssi.c b/sound/soc/sh/rcar/ssi.c
index 7db05fd..7ee89da 100644
--- a/sound/soc/sh/rcar/ssi.c
+++ b/sound/soc/sh/rcar/ssi.c
@@ -403,29 +403,30 @@ static int rsnd_ssi_quit(struct rsnd_mod *mod,
 	struct rsnd_ssi *ssi = rsnd_mod_to_ssi(mod);
 	struct device *dev = rsnd_priv_to_dev(priv);
-	if (rsnd_ssi_is_parent(mod, io))
-		goto rsnd_ssi_quit_end;
+	if (!ssi->usrcnt) {
+		dev_err(dev, "%s[%d] usrcnt error\n",
+			rsnd_mod_name(mod), rsnd_mod_id(mod));
+		return -EIO;
-	if (ssi->err > 0)
-		dev_warn(dev, "%s[%d] under/over flow err = %d\n",
-			 rsnd_mod_name(mod), rsnd_mod_id(mod), ssi->err);
+	if (!rsnd_ssi_is_parent(mod, io)) {
+		if (ssi->err > 0)
+			dev_warn(dev, "%s[%d] under/over flow err = %d\n",
+				 rsnd_mod_name(mod), rsnd_mod_id(mod),
+				 ssi->err);
-	ssi->cr_own	= 0;
-	ssi->err	= 0;
+		ssi->cr_own	= 0;
+		ssi->err	= 0;
-	rsnd_ssi_irq_disable(mod);
+		rsnd_ssi_irq_disable(mod);
-rsnd_ssi_quit_end:
 	rsnd_ssi_master_clk_stop(ssi, io);
 	rsnd_mod_power_off(mod);
 	ssi->usrcnt--;
-	if (ssi->usrcnt < 0)
-		dev_err(dev, "%s[%d] usrcnt error\n",
-			rsnd_mod_name(mod), rsnd_mod_id(mod));
 	return 0;
BtrLinux
Privacy Overview
