ASoC: rk3036: fix platform_no_drv_owner.cocci warnings
Author: kbuild test robot <lkp@intel.com>
sound/soc/codecs/inno_rk3036.c:480:3-8: No need to set .owner here. The core will do it.
 Remove .owner field if calls are used which set it automatically
Generated by: scripts/coccinelle/api/platform_no_drv_owner.cocci
Signed-off-by: Fengguang Wu
Signed-off-by: Mark Brown
 sound/soc/codecs/inno_rk3036.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/sound/soc/codecs/inno_rk3036.c b/sound/soc/codecs/inno_rk3036.c
index 24677a8..9b6e884 100644
--- a/sound/soc/codecs/inno_rk3036.c
+++ b/sound/soc/codecs/inno_rk3036.c
@@ -477,7 +477,6 @@ MODULE_DEVICE_TABLE(of, rk3036_codec_of_match);
 static struct platform_driver rk3036_codec_platform_driver = {
 	.driver = {
 		.name = "rk3036-codec-platform",
-		.owner = THIS_MODULE,
 		.of_match_table = of_match_ptr(rk3036_codec_of_match),
 	.probe = rk3036_codec_platform_probe,
BtrLinux
Privacy Overview
