ASoC: pcm5102a: Remove owner assignment from platform_driver
Author: Fabio Estevam <fabio.estevam@nxp.com>
This platform_driver does not need to set an owner as it will be
populated by the driver core.
Generated by scripts/coccinelle/api/platform_no_drv_owner.cocci.
Signed-off-by: Fabio Estevam
Signed-off-by: Mark Brown
 sound/soc/codecs/pcm5102a.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/sound/soc/codecs/pcm5102a.c b/sound/soc/codecs/pcm5102a.c
index ed51567..8ba322a 100644
--- a/sound/soc/codecs/pcm5102a.c
+++ b/sound/soc/codecs/pcm5102a.c
@@ -57,7 +57,6 @@ static struct platform_driver pcm5102a_codec_driver = {
 	.remove		= pcm5102a_remove,
 	.driver		= {
 		.name	= "pcm5102a-codec",
-		.owner	= THIS_MODULE,
 		.of_match_table = pcm5102a_of_match,
BtrLinux
Privacy Overview
