ASoC: Move dereference after NULL test
If the NULL test on jack is needed, then the derefernce should be after the
NULL test.
A simplified version of the semantic match that detects this problem is as
follows (http://coccinelle.lip6.fr/):
@match exists@
expression x, E;
identifier fld;
* x->fld
... when != \(x = E\|&x\)
* x == NULL
Signed-off-by: Julia Lawall
Signed-off-by: Mark Brown
sound/soc/soc-jack.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/sound/soc/soc-jack.c b/sound/soc/soc-jack.c
index 1d455ab7..1212414 100644
--- a/sound/soc/soc-jack.c
+++ b/sound/soc/soc-jack.c
@@ -58,7 +58,7 @@ EXPORT_SYMBOL_GPL(snd_soc_jack_new);
void snd_soc_jack_report(struct snd_soc_jack *jack, int status, int mask)
- struct snd_soc_codec *codec = jack->card->codec;
+ struct snd_soc_codec *codec;
struct snd_soc_jack_pin *pin;
int enable;
int oldstatus;
@@ -67,6 +67,7 @@ void snd_soc_jack_report(struct snd_soc_jack *jack, int status, int mask)
WARN_ON_ONCE(!jack);
return;
+ codec = jack->card->codec;
mutex_lock(&codec->mutex); |
int enable;
int oldstatus;
return;
