sound/soc/codecs/max9877.c | 14 ++++++--------
1 file changed, 6 insertions(+), 8 deletions(-)
diff --git a/sound/soc/codecs/max9877.c b/sound/soc/codecs/max9877.c
index 29549cd..9aac52d 100644
--- a/sound/soc/codecs/max9877.c
+++ b/sound/soc/codecs/max9877.c
@@ -30,19 +30,17 @@ static struct reg_default max9877_regs[] = {
{ 4, 0x49 },
-static const unsigned int max9877_pgain_tlv[] = {
- TLV_DB_RANGE_HEAD(2),
+static const DECLARE_TLV_DB_RANGE(max9877_pgain_tlv,
0, 1, TLV_DB_SCALE_ITEM(0, 900, 0),
- 2, 2, TLV_DB_SCALE_ITEM(2000, 0, 0),
+ 2, 2, TLV_DB_SCALE_ITEM(2000, 0, 0)
-static const unsigned int max9877_output_tlv[] = {
- TLV_DB_RANGE_HEAD(4),
+static const DECLARE_TLV_DB_RANGE(max9877_output_tlv,
0, 7, TLV_DB_SCALE_ITEM(-7900, 400, 1),
8, 15, TLV_DB_SCALE_ITEM(-4700, 300, 0),
16, 23, TLV_DB_SCALE_ITEM(-2300, 200, 0),
- 24, 31, TLV_DB_SCALE_ITEM(-700, 100, 0),
+ 24, 31, TLV_DB_SCALE_ITEM(-700, 100, 0)
static const char *max9877_out_mode[] = {
"INA -> SPK", |
