ASoC: max9850: Replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGE
Author: Lars-Peter Clausen <lars@metafoo.de>
DECLARE_TLV_DB_RANGE() has the advantage over using TLV_DB_RANGE_HEAD()
that it automatically calculates the number of items in the TLV and is
hence less prone to manual error.
Generate using the following coccinelle script
declarer name DECLARE_TLV_DB_RANGE;
identifier tlv;
constant x;
-unsigned int tlv[] = {
-	TLV_DB_RANGE_HEAD(x),
+DECLARE_TLV_DB_RANGE(tlv,
Signed-off-by: Lars-Peter Clausen
Signed-off-by: Mark Brown
 sound/soc/codecs/max9850.c | 7 +++----
 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/sound/soc/codecs/max9850.c b/sound/soc/codecs/max9850.c
index 481d58f1..3774e42 100644
--- a/sound/soc/codecs/max9850.c
+++ b/sound/soc/codecs/max9850.c
@@ -67,13 +67,12 @@ static const struct regmap_config max9850_regmap = {
 	.cache_type = REGCACHE_RBTREE,
-static const unsigned int max9850_tlv[] = {
-	TLV_DB_RANGE_HEAD(4),
+static const DECLARE_TLV_DB_RANGE(max9850_tlv,
 	0x18, 0x1f, TLV_DB_SCALE_ITEM(-7450, 400, 0),
 	0x20, 0x33, TLV_DB_SCALE_ITEM(-4150, 200, 0),
 	0x34, 0x37, TLV_DB_SCALE_ITEM(-150, 100, 0),
-	0x38, 0x3f, TLV_DB_SCALE_ITEM(250, 50, 0),
+	0x38, 0x3f, TLV_DB_SCALE_ITEM(250, 50, 0)
 static const struct snd_kcontrol_new max9850_controls[] = {
 SOC_SINGLE_TLV("Headphone Volume", MAX9850_VOLUME, 0, 0x3f, 1, max9850_tlv),
BtrLinux
Privacy Overview
