ASoC: max98090: Replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGE
Author: Lars-Peter Clausen <lars@metafoo.de>
DECLARE_TLV_DB_RANGE() has the advantage over using TLV_DB_RANGE_HEAD()
that it automatically calculates the number of items in the TLV and is
hence less prone to manual error.
Generate using the following coccinelle script
declarer name DECLARE_TLV_DB_RANGE;
identifier tlv;
constant x;
-unsigned int tlv[] = {
-	TLV_DB_RANGE_HEAD(x),
+DECLARE_TLV_DB_RANGE(tlv,
Signed-off-by: Lars-Peter Clausen
Signed-off-by: Mark Brown
 sound/soc/codecs/max98090.c | 42 ++++++++++++++++++------------------------
 1 file changed, 18 insertions(+), 24 deletions(-)
diff --git a/sound/soc/codecs/max98090.c b/sound/soc/codecs/max98090.c
index 78268f05..cf8789f 100644
--- a/sound/soc/codecs/max98090.c
+++ b/sound/soc/codecs/max98090.c
@@ -360,22 +360,20 @@ static int max98090_reset(struct max98090_priv *max98090)
 	return ret;
-static const unsigned int max98090_micboost_tlv[] = {
-	TLV_DB_RANGE_HEAD(2),
+static const DECLARE_TLV_DB_RANGE(max98090_micboost_tlv,
 	0, 1, TLV_DB_SCALE_ITEM(0, 2000, 0),
-	2, 2, TLV_DB_SCALE_ITEM(3000, 0, 0),
+	2, 2, TLV_DB_SCALE_ITEM(3000, 0, 0)
 static const DECLARE_TLV_DB_SCALE(max98090_mic_tlv, 0, 100, 0);
 static const DECLARE_TLV_DB_SCALE(max98090_line_single_ended_tlv,
 	-600, 600, 0);
-static const unsigned int max98090_line_tlv[] = {
+static const DECLARE_TLV_DB_RANGE(max98090_line_tlv,
 	0, 3, TLV_DB_SCALE_ITEM(-600, 300, 0),
-	4, 5, TLV_DB_SCALE_ITEM(1400, 600, 0),
+	4, 5, TLV_DB_SCALE_ITEM(1400, 600, 0)
 static const DECLARE_TLV_DB_SCALE(max98090_avg_tlv, 0, 600, 0);
 static const DECLARE_TLV_DB_SCALE(max98090_av_tlv, -1200, 100, 0);
@@ -391,38 +389,34 @@ static const DECLARE_TLV_DB_SCALE(max98090_alccomp_tlv, -3100, 100, 0);
 static const DECLARE_TLV_DB_SCALE(max98090_drcexp_tlv, -6600, 100, 0);
 static const DECLARE_TLV_DB_SCALE(max98090_sdg_tlv, 50, 200, 0);
-static const unsigned int max98090_mixout_tlv[] = {
+static const DECLARE_TLV_DB_RANGE(max98090_mixout_tlv,
 	0, 1, TLV_DB_SCALE_ITEM(-1200, 250, 0),
-	2, 3, TLV_DB_SCALE_ITEM(-600, 600, 0),
+	2, 3, TLV_DB_SCALE_ITEM(-600, 600, 0)
-static const unsigned int max98090_hp_tlv[] = {
-	TLV_DB_RANGE_HEAD(5),
+static const DECLARE_TLV_DB_RANGE(max98090_hp_tlv,
 	0, 6, TLV_DB_SCALE_ITEM(-6700, 400, 0),
 	7, 14, TLV_DB_SCALE_ITEM(-4000, 300, 0),
 	15, 21, TLV_DB_SCALE_ITEM(-1700, 200, 0),
 	22, 27, TLV_DB_SCALE_ITEM(-400, 100, 0),
-	28, 31, TLV_DB_SCALE_ITEM(150, 50, 0),
+	28, 31, TLV_DB_SCALE_ITEM(150, 50, 0)
-static const unsigned int max98090_spk_tlv[] = {
+static const DECLARE_TLV_DB_RANGE(max98090_spk_tlv,
 	0, 4, TLV_DB_SCALE_ITEM(-4800, 400, 0),
 	5, 10, TLV_DB_SCALE_ITEM(-2900, 300, 0),
 	11, 14, TLV_DB_SCALE_ITEM(-1200, 200, 0),
 	15, 29, TLV_DB_SCALE_ITEM(-500, 100, 0),
-	30, 39, TLV_DB_SCALE_ITEM(950, 50, 0),
+	30, 39, TLV_DB_SCALE_ITEM(950, 50, 0)
-static const unsigned int max98090_rcv_lout_tlv[] = {
+static const DECLARE_TLV_DB_RANGE(max98090_rcv_lout_tlv,
 	0, 6, TLV_DB_SCALE_ITEM(-6200, 400, 0),
 	7, 14, TLV_DB_SCALE_ITEM(-3500, 300, 0),
 	15, 21, TLV_DB_SCALE_ITEM(-1200, 200, 0),
 	22, 27, TLV_DB_SCALE_ITEM(100, 100, 0),
-	28, 31, TLV_DB_SCALE_ITEM(650, 50, 0),
+	28, 31, TLV_DB_SCALE_ITEM(650, 50, 0)
 static int max98090_get_enab_tlv(struct snd_kcontrol *kcontrol,
 				struct snd_ctl_elem_value *ucontrol)
BtrLinux
Privacy Overview
