ASoC: max98088: Replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGE
Author: Lars-Peter Clausen <lars@metafoo.de>
DECLARE_TLV_DB_RANGE() has the advantage over using TLV_DB_RANGE_HEAD()
that it automatically calculates the number of items in the TLV and is
hence less prone to manual error.
Generate using the following coccinelle script
declarer name DECLARE_TLV_DB_RANGE;
identifier tlv;
constant x;
-unsigned int tlv[] = {
-	TLV_DB_RANGE_HEAD(x),
+DECLARE_TLV_DB_RANGE(tlv,
Signed-off-by: Lars-Peter Clausen
Signed-off-by: Mark Brown
 sound/soc/codecs/max98088.c | 23 ++++++++++-------------
 1 file changed, 10 insertions(+), 13 deletions(-)
diff --git a/sound/soc/codecs/max98088.c b/sound/soc/codecs/max98088.c
index d0f4534..d326d66 100644
--- a/sound/soc/codecs/max98088.c
+++ b/sound/soc/codecs/max98088.c
@@ -680,29 +680,26 @@ static int max98088_mic2pre_get(struct snd_kcontrol *kcontrol,
        return 0;
-static const unsigned int max98088_micboost_tlv[] = {
-       TLV_DB_RANGE_HEAD(2),
-       0, 1, TLV_DB_SCALE_ITEM(0, 2000, 0),
-       2, 2, TLV_DB_SCALE_ITEM(3000, 0, 0),
+static const DECLARE_TLV_DB_RANGE(max98088_micboost_tlv,
+	0, 1, TLV_DB_SCALE_ITEM(0, 2000, 0),
+	2, 2, TLV_DB_SCALE_ITEM(3000, 0, 0)
-static const unsigned int max98088_hp_tlv[] = {
-	TLV_DB_RANGE_HEAD(5),
+static const DECLARE_TLV_DB_RANGE(max98088_hp_tlv,
 	0, 6, TLV_DB_SCALE_ITEM(-6700, 400, 0),
 	7, 14, TLV_DB_SCALE_ITEM(-4000, 300, 0),
 	15, 21, TLV_DB_SCALE_ITEM(-1700, 200, 0),
 	22, 27, TLV_DB_SCALE_ITEM(-400, 100, 0),
-	28, 31, TLV_DB_SCALE_ITEM(150, 50, 0),
+	28, 31, TLV_DB_SCALE_ITEM(150, 50, 0)
-static const unsigned int max98088_spk_tlv[] = {
+static const DECLARE_TLV_DB_RANGE(max98088_spk_tlv,
 	0, 6, TLV_DB_SCALE_ITEM(-6200, 400, 0),
 	7, 14, TLV_DB_SCALE_ITEM(-3500, 300, 0),
 	15, 21, TLV_DB_SCALE_ITEM(-1200, 200, 0),
 	22, 27, TLV_DB_SCALE_ITEM(100, 100, 0),
-	28, 31, TLV_DB_SCALE_ITEM(650, 50, 0),
+	28, 31, TLV_DB_SCALE_ITEM(650, 50, 0)
 static const struct snd_kcontrol_new max98088_snd_controls[] = {
BtrLinux
Privacy Overview
