ASoC: Intel: constify sst_block_ops structures
Author: Julia Lawall <Julia.Lawall@lip6.fr>
The sst_block_ops structure is never modified, and is thus declared as
const.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall
Acked-by: Jie Yang
Signed-off-by: Mark Brown
 sound/soc/intel/common/sst-dsp-priv.h     | 6 +++---
 sound/soc/intel/common/sst-firmware.c     | 4 ++--
 sound/soc/intel/haswell/sst-haswell-dsp.c | 2 +-
 3 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/sound/soc/intel/common/sst-dsp-priv.h b/sound/soc/intel/common/sst-dsp-priv.h
index 4452cda..81aa1ed 100644
--- a/sound/soc/intel/common/sst-dsp-priv.h
+++ b/sound/soc/intel/common/sst-dsp-priv.h
@@ -243,7 +243,7 @@ struct sst_mem_block {
 	u32 size;			/* block size */
 	u32 index;			/* block index 0..N */
 	enum sst_mem_type type;		/* block memory type IRAM/DRAM */
-	struct sst_block_ops *ops;	/* block operations, if any */
+	const struct sst_block_ops *ops;/* block operations, if any */
 	/* block status */
 	u32 bytes_used;			/* bytes in use by modules */
@@ -378,8 +378,8 @@ void sst_block_free_scratch(struct sst_dsp *dsp);
 /* Register the DSPs memory blocks - would be nice to read from ACPI */
 struct sst_mem_block *sst_mem_block_register(struct sst_dsp *dsp, u32 offset,
-	u32 size, enum sst_mem_type type, struct sst_block_ops *ops, u32 index,
-	void *private);
+	u32 size, enum sst_mem_type type, const struct sst_block_ops *ops,
+	u32 index, void *private);
 void sst_mem_block_unregister_all(struct sst_dsp *dsp);
 /* Create/Free DMA resources */
diff --git a/sound/soc/intel/common/sst-firmware.c b/sound/soc/intel/common/sst-firmware.c
index 1636a1e..bee04a9 100644
--- a/sound/soc/intel/common/sst-firmware.c
+++ b/sound/soc/intel/common/sst-firmware.c
@@ -1014,8 +1014,8 @@ EXPORT_SYMBOL_GPL(sst_module_runtime_restore);
 /* register a DSP memory block for use with FW based modules */
-	void *private)
 	struct sst_mem_block *block;
diff --git a/sound/soc/intel/haswell/sst-haswell-dsp.c b/sound/soc/intel/haswell/sst-haswell-dsp.c
index 7f94920..b2bec36 100644
--- a/sound/soc/intel/haswell/sst-haswell-dsp.c
+++ b/sound/soc/intel/haswell/sst-haswell-dsp.c
@@ -607,7 +607,7 @@ static int hsw_block_disable(struct sst_mem_block *block)
 	return 0;
-static struct sst_block_ops sst_hsw_ops = {
+static const struct sst_block_ops sst_hsw_ops = {
 	.enable = hsw_block_enable,
 	.disable = hsw_block_disable,
BtrLinux
Privacy Overview
