ASoC: imx-pcm-dma: add NULL test
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Add NULL test on call to devm_kzalloc.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression x;
* x = devm_kzalloc(...);
  ... when != x == NULL
  *x
Signed-off-by: Julia Lawall
Acked-by: Nicolin Chen
Signed-off-by: Mark Brown
 sound/soc/fsl/imx-pcm-dma.c | 2 ++
 1 file changed, 2 insertions(+)
diff --git a/sound/soc/fsl/imx-pcm-dma.c b/sound/soc/fsl/imx-pcm-dma.c
index 1fc01ed..f3d3d1f 100644
--- a/sound/soc/fsl/imx-pcm-dma.c
+++ b/sound/soc/fsl/imx-pcm-dma.c
@@ -62,6 +62,8 @@ int imx_pcm_dma_init(struct platform_device *pdev, size_t size)
 	config = devm_kzalloc(&pdev->dev,
 			sizeof(struct snd_dmaengine_pcm_config), GFP_KERNEL);
+	if (!config)
+		return -ENOMEM;
 	*config = imx_dmaengine_pcm_config;
 	if (size)
 		config->prealloc_buffer_size = size;
BtrLinux
Privacy Overview
