ASoC: fsl: fsl_dma: Use true/false for boolean init
Author: Fabio Estevam <fabio.estevam@freescale.com>
Bool initializations should use true and false.  Bool tests don't need
comparisons.  Based on contributions from Joe Perches, Rusty Russell
and Bruce W Allan.
The semantic patch that makes this change is available
in scripts/coccinelle/misc/boolinit.cocci.
More information about semantic patching is available at
http://coccinelle.lip6.fr/
Signed-off-by: Fabio Estevam
Acked-by: Timur Tabi
Signed-off-by: Mark Brown
 sound/soc/fsl/fsl_dma.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/sound/soc/fsl/fsl_dma.c b/sound/soc/fsl/fsl_dma.c
index 93d7e56..ccadefc 100644
--- a/sound/soc/fsl/fsl_dma.c
+++ b/sound/soc/fsl/fsl_dma.c
@@ -445,7 +445,7 @@ static int fsl_dma_open(struct snd_pcm_substream *substream)
 		return ret;
-	dma->assigned = 1;
+	dma->assigned = true;
 	snd_pcm_set_runtime_buffer(substream, &substream->dma_buffer);
 	snd_soc_set_runtime_hwparams(substream, &fsl_dma_hardware);
@@ -814,7 +814,7 @@ static int fsl_dma_close(struct snd_pcm_substream *substream)
 		substream->runtime->private_data = NULL;
-	dma->assigned = 0;
+	dma->assigned = false;
 	return 0;
