ASoC: fsi: Deletion of unnecessary checks before the function call “clk_disable”
Author: Markus Elfring <elfring@users.sourceforge.net>
The clk_disable() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Mark Brown
sound/soc/sh/fsi.c | 9 +++------
1 file changed, 3 insertions(+), 6 deletions(-)
diff --git a/sound/soc/sh/fsi.c b/sound/soc/sh/fsi.c
index 66fddec..eefb161 100644
--- a/sound/soc/sh/fsi.c
+++ b/sound/soc/sh/fsi.c
@@ -842,12 +842,9 @@ static int fsi_clk_disable(struct device *dev,
return -EINVAL;
if (1 == clock->count--) {
- if (clock->xck)
- clk_disable(clock->xck);
- if (clock->ick)
- clk_disable(clock->ick);
- if (clock->div)
- clk_disable(clock->div);
+ clk_disable(clock->xck);
+ clk_disable(clock->ick);
+ clk_disable(clock->div);
return 0; |
return -EINVAL;
- if (clock->xck)
- if (clock->ick)
- if (clock->div)
return 0;
