ASoC: davinci-mcasp.c: Return error code in failure
In this code, 0 is returned on failure, even though other
failures return -ENOMEM or other similar values.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@a@
identifier alloc;
identifier ret;
constant C;
expression x;
x = alloc(...);
if (x == NULL) { <+... \(ret = -C; \| return -C; \) ...+> }
identifier f, a.alloc;
expression ret;
expression x,e1,e2,e3;
ret = 0
... when != ret = e1
*x = alloc(...)
... when != ret = e2
if (x == NULL) { ... when != ret = e3
  return ret;
Signed-off-by: Julia Lawall
Acked-by: Liam Girdwood
Signed-off-by: Mark Brown
 sound/soc/davinci/davinci-mcasp.c | 2 ++
 1 file changed, 2 insertions(+)
diff --git a/sound/soc/davinci/davinci-mcasp.c b/sound/soc/davinci/davinci-mcasp.c
index c8e97dc..86918ee 100644
--- a/sound/soc/davinci/davinci-mcasp.c
+++ b/sound/soc/davinci/davinci-mcasp.c
@@ -898,6 +898,7 @@ static int davinci_mcasp_probe(struct platform_device *pdev)
 	res = platform_get_resource(pdev, IORESOURCE_DMA, 0);
 	if (!res) {
 		dev_err(&pdev->dev, "no DMA resource\n");
+		ret = -ENODEV;
 		goto err_release_region;
@@ -912,6 +913,7 @@ static int davinci_mcasp_probe(struct platform_device *pdev)
 	res = platform_get_resource(pdev, IORESOURCE_DMA, 1);
 	if (!res) {
+		ret = -ENODEV;
BtrLinux
Privacy Overview
