ASoC: cs4349: fix platform_no_drv_owner.cocci warnings
Author: kbuild test robot <fengguang.wu@intel.com>
sound/soc/codecs/cs4349.c:389:3-8: No need to set .owner here. The core will do it.
 Remove .owner field if calls are used which set it automatically
Generated by: scripts/coccinelle/api/platform_no_drv_owner.cocci
CC: Tim Howe
Signed-off-by: Fengguang Wu
Signed-off-by: Mark Brown
 sound/soc/codecs/cs4349.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/sound/soc/codecs/cs4349.c b/sound/soc/codecs/cs4349.c
index 0d010c2..0ac8fc5 100644
--- a/sound/soc/codecs/cs4349.c
+++ b/sound/soc/codecs/cs4349.c
@@ -378,7 +378,6 @@ MODULE_DEVICE_TABLE(i2c, cs4349_i2c_id);
 static struct i2c_driver cs4349_i2c_driver = {
 	.driver = {
 		.name		= "cs4349",
-		.owner		= THIS_MODULE,
 		.of_match_table	= cs4349_of_match,
 	.id_table	= cs4349_i2c_id,
BtrLinux
Privacy Overview
