ASoC: core: Use PTR_RET function
Author: Alexandru Gheorghiu <gheorghiuandru@gmail.com>
Used PTR_RET function instead of IS_ERR and PTR_ERR.
Patch found using coccinelle.
Signed-off-by: Alexandru Gheorghiu
Signed-off-by: Mark Brown
 sound/soc/soc-io.c | 5 +----
 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/sound/soc/soc-io.c b/sound/soc/soc-io.c
index 29183ef..8ca9ecc 100644
--- a/sound/soc/soc-io.c
+++ b/sound/soc/soc-io.c
@@ -158,10 +158,7 @@ int snd_soc_codec_set_cache_io(struct snd_soc_codec *codec,
 		return -EINVAL;
-	if (IS_ERR(codec->control_data))
-		return PTR_ERR(codec->control_data);
-	return 0;
+	return PTR_RET(codec->control_data);
 EXPORT_SYMBOL_GPL(snd_soc_codec_set_cache_io);
 #else
BtrLinux
Privacy Overview
