ASoC: Constify snd_soc_dai_ops structs
Author: Lars-Peter Clausen <lars@metafoo.de>
Commit 1ee46ebd("ASoC: Make the DAI ops constant in the DAI structure")
introduced the possibility to have constant DAI ops structures, yet this is
barley used in both existing drivers and also new drivers being submitted,
although none of them modifies its DAI ops structure. The later is not
surprising since existing drivers are often used as templates for new drivers.
So this patch just constifies all existing snd_soc_dai_ops structs to eliminate
the issue altogether.
The patch was generated with the following coccinelle semantic patch:
identifier ops;
-struct snd_soc_dai_ops ops =
+const struct snd_soc_dai_ops ops =
Signed-off-by: Lars-Peter Clausen
Signed-off-by: Mark Brown
 sound/soc/atmel/atmel_ssc_dai.c   | 2 +-
 sound/soc/au1x/ac97c.c            | 2 +-
 sound/soc/au1x/i2sc.c             | 2 +-
 sound/soc/au1x/psc-ac97.c         | 2 +-
 sound/soc/au1x/psc-i2s.c          | 2 +-
 sound/soc/blackfin/bf5xx-i2s.c    | 2 +-
 sound/soc/blackfin/bf5xx-tdm.c    | 2 +-
 sound/soc/codecs/88pm860x-codec.c | 4 ++--
 sound/soc/codecs/ac97.c           | 2 +-
 sound/soc/codecs/ad1836.c         | 2 +-
 sound/soc/codecs/ad193x.c         | 2 +-
 sound/soc/codecs/adau1373.c       | 2 +-
 sound/soc/codecs/adau1701.c       | 2 +-
 sound/soc/codecs/adav80x.c        | 2 +-
 sound/soc/codecs/ak4104.c         | 2 +-
 sound/soc/codecs/ak4535.c         | 2 +-
 sound/soc/codecs/ak4641.c         | 4 ++--
 sound/soc/codecs/ak4642.c         | 2 +-
 sound/soc/codecs/ak4671.c         | 2 +-
 sound/soc/codecs/alc5623.c        | 2 +-
 sound/soc/codecs/alc5632.c        | 2 +-
 sound/soc/codecs/cq93vc.c         | 2 +-
 sound/soc/codecs/cs4270.c         | 2 +-
 sound/soc/codecs/cs4271.c         | 2 +-
 sound/soc/codecs/cs42l51.c        | 2 +-
 sound/soc/codecs/cs42l73.c        | 2 +-
 sound/soc/codecs/da7210.c         | 2 +-
 sound/soc/codecs/jz4740.c         | 2 +-
 sound/soc/codecs/max98088.c       | 4 ++--
 sound/soc/codecs/max98095.c       | 6 +++---
 sound/soc/codecs/max9850.c        | 2 +-
 sound/soc/codecs/rt5631.c         | 2 +-
 sound/soc/codecs/sgtl5000.c       | 2 +-
 sound/soc/codecs/sn95031.c        | 8 ++++----
 sound/soc/codecs/ssm2602.c        | 2 +-
 sound/soc/codecs/sta32x.c         | 2 +-
 sound/soc/codecs/stac9766.c       | 4 ++--
 sound/soc/codecs/tlv320aic23.c    | 2 +-
 sound/soc/codecs/tlv320aic26.c    | 2 +-
 sound/soc/codecs/tlv320aic32x4.c  | 2 +-
 sound/soc/codecs/tlv320aic3x.c    | 2 +-
 sound/soc/codecs/tlv320dac33.c    | 2 +-
 sound/soc/codecs/twl4030.c        | 4 ++--
 sound/soc/codecs/twl6040.c        | 2 +-
 sound/soc/codecs/uda134x.c        | 2 +-
 sound/soc/codecs/uda1380.c        | 6 +++---
 sound/soc/codecs/wl1273.c         | 2 +-
 sound/soc/codecs/wm5100.c         | 2 +-
 sound/soc/codecs/wm8350.c         | 2 +-
 sound/soc/codecs/wm8400.c         | 2 +-
 sound/soc/codecs/wm8510.c         | 2 +-
 sound/soc/codecs/wm8523.c         | 2 +-
 sound/soc/codecs/wm8580.c         | 4 ++--
 sound/soc/codecs/wm8711.c         | 2 +-
 sound/soc/codecs/wm8728.c         | 2 +-
 sound/soc/codecs/wm8731.c         | 2 +-
 sound/soc/codecs/wm8737.c         | 2 +-
 sound/soc/codecs/wm8741.c         | 2 +-
 sound/soc/codecs/wm8750.c         | 2 +-
 sound/soc/codecs/wm8753.c         | 4 ++--
 sound/soc/codecs/wm8770.c         | 2 +-
 sound/soc/codecs/wm8776.c         | 4 ++--
 sound/soc/codecs/wm8804.c         | 2 +-
 sound/soc/codecs/wm8900.c         | 2 +-
 sound/soc/codecs/wm8903.c         | 2 +-
 sound/soc/codecs/wm8904.c         | 2 +-
 sound/soc/codecs/wm8940.c         | 2 +-
 sound/soc/codecs/wm8955.c         | 2 +-
 sound/soc/codecs/wm8960.c         | 2 +-
 sound/soc/codecs/wm8961.c         | 2 +-
 sound/soc/codecs/wm8962.c         | 2 +-
 sound/soc/codecs/wm8971.c         | 2 +-
 sound/soc/codecs/wm8974.c         | 2 +-
 sound/soc/codecs/wm8978.c         | 2 +-
 sound/soc/codecs/wm8983.c         | 2 +-
 sound/soc/codecs/wm8985.c         | 2 +-
 sound/soc/codecs/wm8988.c         | 2 +-
 sound/soc/codecs/wm8990.c         | 2 +-
 sound/soc/codecs/wm8991.c         | 2 +-
 sound/soc/codecs/wm8993.c         | 2 +-
 sound/soc/codecs/wm8994.c         | 6 +++---
 sound/soc/codecs/wm8995.c         | 6 +++---
 sound/soc/codecs/wm8996.c         | 2 +-
 sound/soc/codecs/wm9081.c         | 2 +-
 sound/soc/codecs/wm9705.c         | 2 +-
 sound/soc/codecs/wm9712.c         | 4 ++--
 sound/soc/codecs/wm9713.c         | 6 +++---
 sound/soc/davinci/davinci-i2s.c   | 2 +-
 sound/soc/davinci/davinci-mcasp.c | 2 +-
 sound/soc/davinci/davinci-vcif.c  | 2 +-
 sound/soc/ep93xx/ep93xx-ac97.c    | 2 +-
 sound/soc/ep93xx/ep93xx-i2s.c     | 2 +-
 sound/soc/fsl/fsl_ssi.c           | 2 +-
 sound/soc/fsl/mpc5200_psc_ac97.c  | 4 ++--
 sound/soc/fsl/mpc5200_psc_i2s.c   | 2 +-
 sound/soc/imx/imx-ssi.c           | 2 +-
 sound/soc/jz4740/jz4740-i2s.c     | 2 +-
 sound/soc/kirkwood/kirkwood-i2s.c | 2 +-
 sound/soc/mxs/mxs-saif.c          | 2 +-
 sound/soc/nuc900/nuc900-ac97.c    | 2 +-
 sound/soc/omap/ams-delta.c        | 2 +-
 sound/soc/omap/omap-hdmi.c        | 2 +-
 sound/soc/omap/omap-mcbsp.c       | 2 +-
 sound/soc/omap/omap-mcpdm.c       | 2 +-
 sound/soc/pxa/pxa-ssp.c           | 2 +-
 sound/soc/pxa/pxa2xx-ac97.c       | 6 +++---
 sound/soc/pxa/pxa2xx-i2s.c        | 2 +-
 sound/soc/s6000/s6000-i2s.c       | 2 +-
 sound/soc/samsung/ac97.c          | 4 ++--
 sound/soc/samsung/i2s.c           | 2 +-
 sound/soc/samsung/pcm.c           | 2 +-
 sound/soc/samsung/s3c2412-i2s.c   | 2 +-
 sound/soc/samsung/s3c24xx-i2s.c   | 2 +-
 sound/soc/samsung/spdif.c         | 2 +-
 sound/soc/sh/fsi.c                | 2 +-
 sound/soc/sh/hac.c                | 2 +-
 sound/soc/sh/siu_dai.c            | 2 +-
 sound/soc/sh/ssi.c                | 2 +-
 sound/soc/soc-core.c              | 2 +-
 sound/soc/tegra/tegra_i2s.c       | 2 +-
 sound/soc/tegra/tegra_spdif.c     | 2 +-
 121 files changed, 147 insertions(+), 147 deletions(-)
diff --git a/sound/soc/atmel/atmel_ssc_dai.c b/sound/soc/atmel/atmel_ssc_dai.c
index 7122509..a67fc9b 100644
--- a/sound/soc/atmel/atmel_ssc_dai.c
+++ b/sound/soc/atmel/atmel_ssc_dai.c
@@ -719,7 +719,7 @@ static int atmel_ssc_remove(struct snd_soc_dai *dai)
 #define ATMEL_SSC_FORMATS (SNDRV_PCM_FMTBIT_S8     | SNDRV_PCM_FMTBIT_S16_LE |\
 			  SNDRV_PCM_FMTBIT_S24_LE | SNDRV_PCM_FMTBIT_S32_LE)
-static struct snd_soc_dai_ops atmel_ssc_dai_ops = {
+static const struct snd_soc_dai_ops atmel_ssc_dai_ops = {
 	.startup	= atmel_ssc_startup,
 	.shutdown	= atmel_ssc_shutdown,
 	.prepare	= atmel_ssc_prepare,
diff --git a/sound/soc/au1x/ac97c.c b/sound/soc/au1x/ac97c.c
index 726bd65..7771934 100644
--- a/sound/soc/au1x/ac97c.c
+++ b/sound/soc/au1x/ac97c.c
@@ -195,7 +195,7 @@ static int alchemy_ac97c_startup(struct snd_pcm_substream *substream,
 	return 0;
-static struct snd_soc_dai_ops alchemy_ac97c_ops = {
+static const struct snd_soc_dai_ops alchemy_ac97c_ops = {
 	.startup		= alchemy_ac97c_startup,
diff --git a/sound/soc/au1x/i2sc.c b/sound/soc/au1x/i2sc.c
index 6bcf48f..2d5f755 100644
--- a/sound/soc/au1x/i2sc.c
+++ b/sound/soc/au1x/i2sc.c
@@ -201,7 +201,7 @@ static int au1xi2s_startup(struct snd_pcm_substream *substream,
 	return 0;
-static const struct snd_soc_dai_ops au1xi2s_dai_ops = {
+static const const struct snd_soc_dai_ops au1xi2s_dai_ops = {
 	.startup	= au1xi2s_startup,
 	.trigger	= au1xi2s_trigger,
 	.hw_params	= au1xi2s_hw_params,
diff --git a/sound/soc/au1x/psc-ac97.c b/sound/soc/au1x/psc-ac97.c
index 0c6acd5..87daf45 100644
--- a/sound/soc/au1x/psc-ac97.c
+++ b/sound/soc/au1x/psc-ac97.c
@@ -337,7 +337,7 @@ static int au1xpsc_ac97_probe(struct snd_soc_dai *dai)
 	return au1xpsc_ac97_workdata ? 0 : -ENODEV;
-static struct snd_soc_dai_ops au1xpsc_ac97_dai_ops = {
+static const struct snd_soc_dai_ops au1xpsc_ac97_dai_ops = {
 	.startup	= au1xpsc_ac97_startup,
 	.trigger	= au1xpsc_ac97_trigger,
 	.hw_params	= au1xpsc_ac97_hw_params,
diff --git a/sound/soc/au1x/psc-i2s.c b/sound/soc/au1x/psc-i2s.c
index e03c5ce..f7714d5 100644
--- a/sound/soc/au1x/psc-i2s.c
+++ b/sound/soc/au1x/psc-i2s.c
@@ -265,7 +265,7 @@ static int au1xpsc_i2s_startup(struct snd_pcm_substream *substream,
 	return 0;
-static struct snd_soc_dai_ops au1xpsc_i2s_dai_ops = {
+static const struct snd_soc_dai_ops au1xpsc_i2s_dai_ops = {
 	.startup	= au1xpsc_i2s_startup,
 	.trigger	= au1xpsc_i2s_trigger,
 	.hw_params	= au1xpsc_i2s_hw_params,
diff --git a/sound/soc/blackfin/bf5xx-i2s.c b/sound/soc/blackfin/bf5xx-i2s.c
index 00cc3e0..b31662e 100644
--- a/sound/soc/blackfin/bf5xx-i2s.c
+++ b/sound/soc/blackfin/bf5xx-i2s.c
@@ -223,7 +223,7 @@ static int bf5xx_i2s_resume(struct snd_soc_dai *dai)
 	 SNDRV_PCM_FMTBIT_S24_LE | \
-static struct snd_soc_dai_ops bf5xx_i2s_dai_ops = {
+static const struct snd_soc_dai_ops bf5xx_i2s_dai_ops = {
 	.shutdown	= bf5xx_i2s_shutdown,
 	.hw_params	= bf5xx_i2s_hw_params,
 	.set_fmt	= bf5xx_i2s_set_dai_fmt,
diff --git a/sound/soc/blackfin/bf5xx-tdm.c b/sound/soc/blackfin/bf5xx-tdm.c
index a822d1e..7876b50 100644
--- a/sound/soc/blackfin/bf5xx-tdm.c
+++ b/sound/soc/blackfin/bf5xx-tdm.c
@@ -226,7 +226,7 @@ static int bf5xx_tdm_resume(struct snd_soc_dai *dai)
 #define bf5xx_tdm_resume       NULL
 #endif
-static struct snd_soc_dai_ops bf5xx_tdm_dai_ops = {
+static const struct snd_soc_dai_ops bf5xx_tdm_dai_ops = {
 	.hw_params      = bf5xx_tdm_hw_params,
 	.set_fmt        = bf5xx_tdm_set_dai_fmt,
 	.shutdown       = bf5xx_tdm_shutdown,
diff --git a/sound/soc/codecs/88pm860x-codec.c b/sound/soc/codecs/88pm860x-codec.c
index 5ca122e..ea305b8 100644
--- a/sound/soc/codecs/88pm860x-codec.c
+++ b/sound/soc/codecs/88pm860x-codec.c
@@ -1198,14 +1198,14 @@ static int pm860x_set_bias_level(struct snd_soc_codec *codec,
 	return 0;
-static struct snd_soc_dai_ops pm860x_pcm_dai_ops = {
+static const struct snd_soc_dai_ops pm860x_pcm_dai_ops = {
 	.digital_mute	= pm860x_digital_mute,
 	.hw_params	= pm860x_pcm_hw_params,
 	.set_fmt	= pm860x_pcm_set_dai_fmt,
 	.set_sysclk	= pm860x_set_dai_sysclk,
-static struct snd_soc_dai_ops pm860x_i2s_dai_ops = {
+static const struct snd_soc_dai_ops pm860x_i2s_dai_ops = {
 	.hw_params	= pm860x_i2s_hw_params,
 	.set_fmt	= pm860x_i2s_set_dai_fmt,
diff --git a/sound/soc/codecs/ac97.c b/sound/soc/codecs/ac97.c
index e715186..8f32167 100644
--- a/sound/soc/codecs/ac97.c
+++ b/sound/soc/codecs/ac97.c
@@ -39,7 +39,7 @@ static int ac97_prepare(struct snd_pcm_substream *substream,
 		SNDRV_PCM_RATE_22050 | SNDRV_PCM_RATE_44100 |\
 		SNDRV_PCM_RATE_48000)
-static struct snd_soc_dai_ops ac97_dai_ops = {
+static const struct snd_soc_dai_ops ac97_dai_ops = {
 	.prepare	= ac97_prepare,
diff --git a/sound/soc/codecs/ad1836.c b/sound/soc/codecs/ad1836.c
index 4e5c572..fab0948 100644
--- a/sound/soc/codecs/ad1836.c
+++ b/sound/soc/codecs/ad1836.c
@@ -189,7 +189,7 @@ static int ad1836_hw_params(struct snd_pcm_substream *substream,
 	return 0;
-static struct snd_soc_dai_ops ad1836_dai_ops = {
+static const struct snd_soc_dai_ops ad1836_dai_ops = {
 	.hw_params = ad1836_hw_params,
 	.set_fmt = ad1836_set_dai_fmt,
diff --git a/sound/soc/codecs/ad193x.c b/sound/soc/codecs/ad193x.c
index 1206021..1901cd2 100644
--- a/sound/soc/codecs/ad193x.c
+++ b/sound/soc/codecs/ad193x.c
@@ -312,7 +312,7 @@ static int ad193x_hw_params(struct snd_pcm_substream *substream,
 	return 0;
-static struct snd_soc_dai_ops ad193x_dai_ops = {
+static const struct snd_soc_dai_ops ad193x_dai_ops = {
 	.hw_params = ad193x_hw_params,
 	.digital_mute = ad193x_mute,
 	.set_tdm_slot = ad193x_set_tdm_slot,
diff --git a/sound/soc/codecs/adau1373.c b/sound/soc/codecs/adau1373.c
index 45c6302..2e040af 100644
--- a/sound/soc/codecs/adau1373.c
+++ b/sound/soc/codecs/adau1373.c
@@ -1042,7 +1042,7 @@ static int adau1373_set_dai_sysclk(struct snd_soc_dai *dai,
 	return 0;
-static const struct snd_soc_dai_ops adau1373_dai_ops = {
+static const const struct snd_soc_dai_ops adau1373_dai_ops = {
 	.hw_params	= adau1373_hw_params,
 	.set_sysclk	= adau1373_set_dai_sysclk,
 	.set_fmt	= adau1373_set_dai_fmt,
diff --git a/sound/soc/codecs/adau1701.c b/sound/soc/codecs/adau1701.c
index 8b7e1c5..c69bdfe 100644
--- a/sound/soc/codecs/adau1701.c
+++ b/sound/soc/codecs/adau1701.c
@@ -427,7 +427,7 @@ static int adau1701_set_sysclk(struct snd_soc_codec *codec, int clk_id,
 #define ADAU1701_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE |\
 	SNDRV_PCM_FMTBIT_S24_LE)
-static const struct snd_soc_dai_ops adau1701_dai_ops = {
+static const const struct snd_soc_dai_ops adau1701_dai_ops = {
 	.set_fmt	= adau1701_set_dai_fmt,
 	.hw_params	= adau1701_hw_params,
 	.digital_mute	= adau1701_digital_mute,
diff --git a/sound/soc/codecs/adav80x.c b/sound/soc/codecs/adav80x.c
index f9f0894..d927feb 100644
--- a/sound/soc/codecs/adav80x.c
+++ b/sound/soc/codecs/adav80x.c
@@ -718,7 +718,7 @@ static void adav80x_dai_shutdown(struct snd_pcm_substream *substream,
 		adav80x->rate = 0;
-static const struct snd_soc_dai_ops adav80x_dai_ops = {
+static const const struct snd_soc_dai_ops adav80x_dai_ops = {
 	.set_fmt = adav80x_set_dai_fmt,
 	.hw_params = adav80x_hw_params,
 	.startup = adav80x_dai_startup,
diff --git a/sound/soc/codecs/ak4104.c b/sound/soc/codecs/ak4104.c
index d3b29dc..152420c 100644
--- a/sound/soc/codecs/ak4104.c
+++ b/sound/soc/codecs/ak4104.c
@@ -170,7 +170,7 @@ static int ak4104_hw_params(struct snd_pcm_substream *substream,
 	return ak4104_spi_write(codec, AK4104_REG_CHN_STATUS(3), val);
-static struct snd_soc_dai_ops ak4101_dai_ops = {
+static const struct snd_soc_dai_ops ak4101_dai_ops = {
 	.hw_params = ak4104_hw_params,
 	.set_fmt = ak4104_set_dai_fmt,
diff --git a/sound/soc/codecs/ak4535.c b/sound/soc/codecs/ak4535.c
index 95d782d..f6c4734 100644
--- a/sound/soc/codecs/ak4535.c
+++ b/sound/soc/codecs/ak4535.c
@@ -331,7 +331,7 @@ static int ak4535_set_bias_level(struct snd_soc_codec *codec,
 		SNDRV_PCM_RATE_16000 | SNDRV_PCM_RATE_22050 |\
 		SNDRV_PCM_RATE_44100 | SNDRV_PCM_RATE_48000)
-static struct snd_soc_dai_ops ak4535_dai_ops = {
+static const struct snd_soc_dai_ops ak4535_dai_ops = {
 	.hw_params	= ak4535_hw_params,
 	.set_fmt	= ak4535_set_dai_fmt,
 	.digital_mute	= ak4535_mute,
diff --git a/sound/soc/codecs/ak4641.c b/sound/soc/codecs/ak4641.c
index 7783858..3657c76 100644
--- a/sound/soc/codecs/ak4641.c
+++ b/sound/soc/codecs/ak4641.c
@@ -442,14 +442,14 @@ static int ak4641_set_bias_level(struct snd_soc_codec *codec,
 			 SNDRV_PCM_RATE_16000)
 #define AK4641_FORMATS	(SNDRV_PCM_FMTBIT_S16_LE)
-static struct snd_soc_dai_ops ak4641_i2s_dai_ops = {
+static const struct snd_soc_dai_ops ak4641_i2s_dai_ops = {
 	.hw_params    = ak4641_i2s_hw_params,
 	.set_fmt      = ak4641_i2s_set_dai_fmt,
 	.digital_mute = ak4641_mute,
 	.set_sysclk   = ak4641_set_dai_sysclk,
-static struct snd_soc_dai_ops ak4641_pcm_dai_ops = {
+static const struct snd_soc_dai_ops ak4641_pcm_dai_ops = {
 	.hw_params    = NULL, /* rates are controlled by BT chip */
 	.set_fmt      = ak4641_pcm_set_dai_fmt,
diff --git a/sound/soc/codecs/ak4642.c b/sound/soc/codecs/ak4642.c
index 859e015..c887ddf 100644
--- a/sound/soc/codecs/ak4642.c
+++ b/sound/soc/codecs/ak4642.c
@@ -435,7 +435,7 @@ static int ak4642_set_bias_level(struct snd_soc_codec *codec,
 	return 0;
-static struct snd_soc_dai_ops ak4642_dai_ops = {
+static const struct snd_soc_dai_ops ak4642_dai_ops = {
 	.startup	= ak4642_dai_startup,
 	.shutdown	= ak4642_dai_shutdown,
 	.set_sysclk	= ak4642_dai_set_sysclk,
diff --git a/sound/soc/codecs/ak4671.c b/sound/soc/codecs/ak4671.c
index de9ff66..4f5c69f 100644
--- a/sound/soc/codecs/ak4671.c
+++ b/sound/soc/codecs/ak4671.c
@@ -594,7 +594,7 @@ static int ak4671_set_bias_level(struct snd_soc_codec *codec,
 #define AK4671_FORMATS		SNDRV_PCM_FMTBIT_S16_LE
-static struct snd_soc_dai_ops ak4671_dai_ops = {
+static const struct snd_soc_dai_ops ak4671_dai_ops = {
 	.hw_params	= ak4671_hw_params,
 	.set_sysclk	= ak4671_set_dai_sysclk,
 	.set_fmt	= ak4671_set_dai_fmt,
diff --git a/sound/soc/codecs/alc5623.c b/sound/soc/codecs/alc5623.c
index 984b14b..88647d3 100644
--- a/sound/soc/codecs/alc5623.c
+++ b/sound/soc/codecs/alc5623.c
@@ -839,7 +839,7 @@ static int alc5623_set_bias_level(struct snd_soc_codec *codec,
 			| SNDRV_PCM_FMTBIT_S24_LE \
-static struct snd_soc_dai_ops alc5623_dai_ops = {
+static const struct snd_soc_dai_ops alc5623_dai_ops = {
 		.hw_params = alc5623_pcm_hw_params,
 		.digital_mute = alc5623_mute,
 		.set_fmt = alc5623_set_dai_fmt,
diff --git a/sound/soc/codecs/alc5632.c b/sound/soc/codecs/alc5632.c
index 2d77665..3f750de 100644
--- a/sound/soc/codecs/alc5632.c
+++ b/sound/soc/codecs/alc5632.c
@@ -924,7 +924,7 @@ static int alc5632_set_bias_level(struct snd_soc_codec *codec,
-static struct snd_soc_dai_ops alc5632_dai_ops = {
+static const struct snd_soc_dai_ops alc5632_dai_ops = {
 		.hw_params = alc5632_pcm_hw_params,
 		.digital_mute = alc5632_mute,
 		.set_fmt = alc5632_set_dai_fmt,
diff --git a/sound/soc/codecs/cq93vc.c b/sound/soc/codecs/cq93vc.c
index 46dbfd0..cbb3028 100644
--- a/sound/soc/codecs/cq93vc.c
+++ b/sound/soc/codecs/cq93vc.c
@@ -122,7 +122,7 @@ static int cq93vc_set_bias_level(struct snd_soc_codec *codec,
 #define CQ93VC_RATES	(SNDRV_PCM_RATE_8000 | SNDRV_PCM_RATE_16000)
 #define CQ93VC_FORMATS	(SNDRV_PCM_FMTBIT_U8 | SNDRV_PCM_FMTBIT_S16_LE)
-static struct snd_soc_dai_ops cq93vc_dai_ops = {
+static const struct snd_soc_dai_ops cq93vc_dai_ops = {
 	.digital_mute	= cq93vc_mute,
 	.set_sysclk	= cq93vc_set_dai_sysclk,
diff --git a/sound/soc/codecs/cs4270.c b/sound/soc/codecs/cs4270.c
index 73f46eb..5396b91 100644
--- a/sound/soc/codecs/cs4270.c
+++ b/sound/soc/codecs/cs4270.c
@@ -447,7 +447,7 @@ static const struct snd_kcontrol_new cs4270_snd_controls[] = {
 		snd_soc_get_volsw, cs4270_soc_put_mute),
-static struct snd_soc_dai_ops cs4270_dai_ops = {
+static const struct snd_soc_dai_ops cs4270_dai_ops = {
 	.hw_params	= cs4270_hw_params,
 	.set_sysclk	= cs4270_set_dai_sysclk,
 	.set_fmt	= cs4270_set_dai_fmt,
diff --git a/sound/soc/codecs/cs4271.c b/sound/soc/codecs/cs4271.c
index 69fde15..a6f77a8 100644
--- a/sound/soc/codecs/cs4271.c
+++ b/sound/soc/codecs/cs4271.c
@@ -402,7 +402,7 @@ static const struct snd_kcontrol_new cs4271_snd_controls[] = {
 		7, 1, 1),
-static struct snd_soc_dai_ops cs4271_dai_ops = {
+static const struct snd_soc_dai_ops cs4271_dai_ops = {
 	.hw_params	= cs4271_hw_params,
 	.set_sysclk	= cs4271_set_dai_sysclk,
 	.set_fmt	= cs4271_set_dai_fmt,
diff --git a/sound/soc/codecs/cs42l51.c b/sound/soc/codecs/cs42l51.c
index 00718b5..e378c4d 100644
--- a/sound/soc/codecs/cs42l51.c
+++ b/sound/soc/codecs/cs42l51.c
@@ -483,7 +483,7 @@ static int cs42l51_dai_mute(struct snd_soc_dai *dai, int mute)
 	return snd_soc_write(codec, CS42L51_DAC_OUT_CTL, reg);
-static struct snd_soc_dai_ops cs42l51_dai_ops = {
+static const struct snd_soc_dai_ops cs42l51_dai_ops = {
 	.hw_params      = cs42l51_hw_params,
 	.set_sysclk     = cs42l51_set_dai_sysclk,
 	.set_fmt        = cs42l51_set_dai_fmt,
diff --git a/sound/soc/codecs/cs42l73.c b/sound/soc/codecs/cs42l73.c
index d09578f..75d80b2 100644
--- a/sound/soc/codecs/cs42l73.c
+++ b/sound/soc/codecs/cs42l73.c
@@ -1190,7 +1190,7 @@ static int cs42l73_pcm_startup(struct snd_pcm_substream *substream,
 #define CS42L73_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE |\
-static const struct snd_soc_dai_ops cs42l73_ops = {
+static const const struct snd_soc_dai_ops cs42l73_ops = {
 	.startup = cs42l73_pcm_startup,
 	.hw_params = cs42l73_pcm_hw_params,
 	.set_fmt = cs42l73_set_dai_fmt,
diff --git a/sound/soc/codecs/da7210.c b/sound/soc/codecs/da7210.c
index 8b5848a..8ef820f 100644
--- a/sound/soc/codecs/da7210.c
+++ b/sound/soc/codecs/da7210.c
@@ -761,7 +761,7 @@ static int da7210_mute(struct snd_soc_dai *dai, int mute)
 /* DAI operations */
-static struct snd_soc_dai_ops da7210_dai_ops = {
+static const struct snd_soc_dai_ops da7210_dai_ops = {
 	.hw_params	= da7210_hw_params,
 	.set_fmt	= da7210_set_dai_fmt,
 	.digital_mute	= da7210_mute,
diff --git a/sound/soc/codecs/jz4740.c b/sound/soc/codecs/jz4740.c
index e373f8f..64a479c 100644
--- a/sound/soc/codecs/jz4740.c
+++ b/sound/soc/codecs/jz4740.c
@@ -206,7 +206,7 @@ static int jz4740_codec_hw_params(struct snd_pcm_substream *substream,
 	return 0;
-static struct snd_soc_dai_ops jz4740_codec_dai_ops = {
+static const struct snd_soc_dai_ops jz4740_codec_dai_ops = {
 	.hw_params = jz4740_codec_hw_params,
diff --git a/sound/soc/codecs/max98088.c b/sound/soc/codecs/max98088.c
index ebbf63c..48a52a1 100644
--- a/sound/soc/codecs/max98088.c
+++ b/sound/soc/codecs/max98088.c
@@ -1650,14 +1650,14 @@ static int max98088_set_bias_level(struct snd_soc_codec *codec,
 #define MAX98088_RATES SNDRV_PCM_RATE_8000_96000
 #define MAX98088_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S24_LE)
-static struct snd_soc_dai_ops max98088_dai1_ops = {
+static const struct snd_soc_dai_ops max98088_dai1_ops = {
        .set_sysclk = max98088_dai_set_sysclk,
        .set_fmt = max98088_dai1_set_fmt,
        .hw_params = max98088_dai1_hw_params,
        .digital_mute = max98088_dai1_digital_mute,
-static struct snd_soc_dai_ops max98088_dai2_ops = {
+static const struct snd_soc_dai_ops max98088_dai2_ops = {
        .set_fmt = max98088_dai2_set_fmt,
        .hw_params = max98088_dai2_hw_params,
diff --git a/sound/soc/codecs/max98095.c b/sound/soc/codecs/max98095.c
index 26d7b08..cc712d5 100644
--- a/sound/soc/codecs/max98095.c
+++ b/sound/soc/codecs/max98095.c
@@ -1782,19 +1782,19 @@ static int max98095_set_bias_level(struct snd_soc_codec *codec,
 #define MAX98095_RATES SNDRV_PCM_RATE_8000_96000
 #define MAX98095_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S24_LE)
-static struct snd_soc_dai_ops max98095_dai1_ops = {
+static const struct snd_soc_dai_ops max98095_dai1_ops = {
 	.set_sysclk = max98095_dai_set_sysclk,
 	.set_fmt = max98095_dai1_set_fmt,
 	.hw_params = max98095_dai1_hw_params,
-static struct snd_soc_dai_ops max98095_dai2_ops = {
+static const struct snd_soc_dai_ops max98095_dai2_ops = {
 	.set_fmt = max98095_dai2_set_fmt,
 	.hw_params = max98095_dai2_hw_params,
-static struct snd_soc_dai_ops max98095_dai3_ops = {
+static const struct snd_soc_dai_ops max98095_dai3_ops = {
 	.set_fmt = max98095_dai3_set_fmt,
 	.hw_params = max98095_dai3_hw_params,
diff --git a/sound/soc/codecs/max9850.c b/sound/soc/codecs/max9850.c
index 208d2ee..94c2b58 100644
--- a/sound/soc/codecs/max9850.c
+++ b/sound/soc/codecs/max9850.c
@@ -254,7 +254,7 @@ static int max9850_set_bias_level(struct snd_soc_codec *codec,
 #define MAX9850_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE |\
-static struct snd_soc_dai_ops max9850_dai_ops = {
+static const struct snd_soc_dai_ops max9850_dai_ops = {
 	.hw_params	= max9850_hw_params,
 	.set_sysclk	= max9850_set_dai_sysclk,
 	.set_fmt	= max9850_set_dai_fmt,
diff --git a/sound/soc/codecs/rt5631.c b/sound/soc/codecs/rt5631.c
index 4646e80..dac4d05 100644
--- a/sound/soc/codecs/rt5631.c
+++ b/sound/soc/codecs/rt5631.c
@@ -1664,7 +1664,7 @@ static int rt5631_resume(struct snd_soc_codec *codec)
 			SNDRV_PCM_FMTBIT_S8)
-static struct snd_soc_dai_ops rt5631_ops = {
+static const struct snd_soc_dai_ops rt5631_ops = {
 	.hw_params = rt5631_hifi_pcm_params,
 	.set_fmt = rt5631_hifi_codec_set_dai_fmt,
 	.set_sysclk = rt5631_hifi_codec_set_dai_sysclk,
diff --git a/sound/soc/codecs/sgtl5000.c b/sound/soc/codecs/sgtl5000.c
index bbcf921..1a6564b 100644
--- a/sound/soc/codecs/sgtl5000.c
+++ b/sound/soc/codecs/sgtl5000.c
@@ -923,7 +923,7 @@ static int sgtl5000_set_bias_level(struct snd_soc_codec *codec,
 			SNDRV_PCM_FMTBIT_S24_LE |\
-static struct snd_soc_dai_ops sgtl5000_ops = {
+static const struct snd_soc_dai_ops sgtl5000_ops = {
 	.hw_params = sgtl5000_pcm_hw_params,
 	.digital_mute = sgtl5000_digital_mute,
 	.set_fmt = sgtl5000_set_dai_fmt,
diff --git a/sound/soc/codecs/sn95031.c b/sound/soc/codecs/sn95031.c
index 887d618..65f2ef9 100644
--- a/sound/soc/codecs/sn95031.c
+++ b/sound/soc/codecs/sn95031.c
@@ -698,21 +698,21 @@ static int sn95031_pcm_hw_params(struct snd_pcm_substream *substream,
 /* Codec DAI section */
-static struct snd_soc_dai_ops sn95031_headset_dai_ops = {
+static const struct snd_soc_dai_ops sn95031_headset_dai_ops = {
 	.digital_mute	= sn95031_pcm_hs_mute,
 	.hw_params	= sn95031_pcm_hw_params,
-static struct snd_soc_dai_ops sn95031_speaker_dai_ops = {
+static const struct snd_soc_dai_ops sn95031_speaker_dai_ops = {
 	.digital_mute	= sn95031_pcm_spkr_mute,
-static struct snd_soc_dai_ops sn95031_vib1_dai_ops = {
+static const struct snd_soc_dai_ops sn95031_vib1_dai_ops = {
-static struct snd_soc_dai_ops sn95031_vib2_dai_ops = {
+static const struct snd_soc_dai_ops sn95031_vib2_dai_ops = {
diff --git a/sound/soc/codecs/ssm2602.c b/sound/soc/codecs/ssm2602.c
index 3cb3271..620411c 100644
--- a/sound/soc/codecs/ssm2602.c
+++ b/sound/soc/codecs/ssm2602.c
@@ -498,7 +498,7 @@ static int ssm2602_set_bias_level(struct snd_soc_codec *codec,
 #define SSM2602_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE |\
-static struct snd_soc_dai_ops ssm2602_dai_ops = {
+static const struct snd_soc_dai_ops ssm2602_dai_ops = {
 	.startup	= ssm2602_startup,
 	.hw_params	= ssm2602_hw_params,
 	.shutdown	= ssm2602_shutdown,
diff --git a/sound/soc/codecs/sta32x.c b/sound/soc/codecs/sta32x.c
index 3b0deaf..e2b1cde 100644
--- a/sound/soc/codecs/sta32x.c
+++ b/sound/soc/codecs/sta32x.c
@@ -783,7 +783,7 @@ static int sta32x_set_bias_level(struct snd_soc_codec *codec,
 	return 0;
-static struct snd_soc_dai_ops sta32x_dai_ops = {
+static const struct snd_soc_dai_ops sta32x_dai_ops = {
 	.hw_params	= sta32x_hw_params,
 	.set_sysclk	= sta32x_set_dai_sysclk,
 	.set_fmt	= sta32x_set_dai_fmt,
diff --git a/sound/soc/codecs/stac9766.c b/sound/soc/codecs/stac9766.c
index 78b2b50..e4783a4 100644
--- a/sound/soc/codecs/stac9766.c
+++ b/sound/soc/codecs/stac9766.c
@@ -286,11 +286,11 @@ reset:
 	return 0;
-static struct snd_soc_dai_ops stac9766_dai_ops_analog = {
+static const struct snd_soc_dai_ops stac9766_dai_ops_analog = {
 	.prepare = ac97_analog_prepare,
-static struct snd_soc_dai_ops stac9766_dai_ops_digital = {
+static const struct snd_soc_dai_ops stac9766_dai_ops_digital = {
 	.prepare = ac97_digital_prepare,
diff --git a/sound/soc/codecs/tlv320aic23.c b/sound/soc/codecs/tlv320aic23.c
index 336de8f..9782631 100644
--- a/sound/soc/codecs/tlv320aic23.c
+++ b/sound/soc/codecs/tlv320aic23.c
@@ -503,7 +503,7 @@ static int tlv320aic23_set_bias_level(struct snd_soc_codec *codec,
 #define AIC23_FORMATS	(SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE | \
 			 SNDRV_PCM_FMTBIT_S24_3LE | SNDRV_PCM_FMTBIT_S32_LE)
-static struct snd_soc_dai_ops tlv320aic23_dai_ops = {
+static const struct snd_soc_dai_ops tlv320aic23_dai_ops = {
 	.prepare	= tlv320aic23_pcm_prepare,
 	.hw_params	= tlv320aic23_hw_params,
 	.shutdown	= tlv320aic23_shutdown,
diff --git a/sound/soc/codecs/tlv320aic26.c b/sound/soc/codecs/tlv320aic26.c
index 7859bdc..86d1fa3 100644
--- a/sound/soc/codecs/tlv320aic26.c
+++ b/sound/soc/codecs/tlv320aic26.c
@@ -275,7 +275,7 @@ static int aic26_set_fmt(struct snd_soc_dai *codec_dai, unsigned int fmt)
 #define AIC26_FORMATS	(SNDRV_PCM_FMTBIT_S8     | SNDRV_PCM_FMTBIT_S16_BE |\
 			 SNDRV_PCM_FMTBIT_S24_BE | SNDRV_PCM_FMTBIT_S32_BE)
-static struct snd_soc_dai_ops aic26_dai_ops = {
+static const struct snd_soc_dai_ops aic26_dai_ops = {
 	.hw_params	= aic26_hw_params,
 	.digital_mute	= aic26_mute,
 	.set_sysclk	= aic26_set_sysclk,
diff --git a/sound/soc/codecs/tlv320aic32x4.c b/sound/soc/codecs/tlv320aic32x4.c
index b21c610..d2e38af 100644
--- a/sound/soc/codecs/tlv320aic32x4.c
+++ b/sound/soc/codecs/tlv320aic32x4.c
@@ -597,7 +597,7 @@ static int aic32x4_set_bias_level(struct snd_soc_codec *codec,
 #define AIC32X4_FORMATS	(SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE \
-static struct snd_soc_dai_ops aic32x4_ops = {
+static const struct snd_soc_dai_ops aic32x4_ops = {
 	.hw_params = aic32x4_hw_params,
 	.digital_mute = aic32x4_mute,
 	.set_fmt = aic32x4_set_dai_fmt,
diff --git a/sound/soc/codecs/tlv320aic3x.c b/sound/soc/codecs/tlv320aic3x.c
index 2e2bf18..7d665ea 100644
--- a/sound/soc/codecs/tlv320aic3x.c
+++ b/sound/soc/codecs/tlv320aic3x.c
@@ -1244,7 +1244,7 @@ EXPORT_SYMBOL_GPL(aic3x_button_pressed);
 #define AIC3X_FORMATS	(SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE | \
-static struct snd_soc_dai_ops aic3x_dai_ops = {
+static const struct snd_soc_dai_ops aic3x_dai_ops = {
 	.hw_params	= aic3x_hw_params,
 	.digital_mute	= aic3x_mute,
 	.set_sysclk	= aic3x_set_dai_sysclk,
diff --git a/sound/soc/codecs/tlv320dac33.c b/sound/soc/codecs/tlv320dac33.c
index dc8a2b2..abcb97e 100644
--- a/sound/soc/codecs/tlv320dac33.c
+++ b/sound/soc/codecs/tlv320dac33.c
@@ -1499,7 +1499,7 @@ static struct snd_soc_codec_driver soc_codec_dev_tlv320dac33 = {
 #define DAC33_FORMATS	(SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S32_LE)
-static struct snd_soc_dai_ops dac33_dai_ops = {
+static const struct snd_soc_dai_ops dac33_dai_ops = {
 	.startup	= dac33_startup,
 	.shutdown	= dac33_shutdown,
 	.hw_params	= dac33_hw_params,
diff --git a/sound/soc/codecs/twl4030.c b/sound/soc/codecs/twl4030.c
index f798247..2a3a528 100644
--- a/sound/soc/codecs/twl4030.c
+++ b/sound/soc/codecs/twl4030.c
@@ -2149,7 +2149,7 @@ static int twl4030_voice_set_tristate(struct snd_soc_dai *dai, int tristate)
 #define TWL4030_RATES	 (SNDRV_PCM_RATE_8000_48000)
 #define TWL4030_FORMATS	 (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S32_LE)
-static struct snd_soc_dai_ops twl4030_dai_hifi_ops = {
+static const struct snd_soc_dai_ops twl4030_dai_hifi_ops = {
 	.startup	= twl4030_startup,
 	.shutdown	= twl4030_shutdown,
 	.hw_params	= twl4030_hw_params,
@@ -2158,7 +2158,7 @@ static struct snd_soc_dai_ops twl4030_dai_hifi_ops = {
 	.set_tristate	= twl4030_set_tristate,
-static struct snd_soc_dai_ops twl4030_dai_voice_ops = {
+static const struct snd_soc_dai_ops twl4030_dai_voice_ops = {
 	.startup	= twl4030_voice_startup,
 	.shutdown	= twl4030_voice_shutdown,
 	.hw_params	= twl4030_voice_hw_params,
diff --git a/sound/soc/codecs/twl6040.c b/sound/soc/codecs/twl6040.c
index 73e11f0..17930ed 100644
--- a/sound/soc/codecs/twl6040.c
+++ b/sound/soc/codecs/twl6040.c
@@ -1397,7 +1397,7 @@ static int twl6040_set_dai_sysclk(struct snd_soc_dai *codec_dai,
 	return 0;
-static struct snd_soc_dai_ops twl6040_dai_ops = {
+static const struct snd_soc_dai_ops twl6040_dai_ops = {
 	.startup	= twl6040_startup,
 	.hw_params	= twl6040_hw_params,
 	.prepare	= twl6040_prepare,
diff --git a/sound/soc/codecs/uda134x.c b/sound/soc/codecs/uda134x.c
index a7b8f30..486aef6 100644
--- a/sound/soc/codecs/uda134x.c
+++ b/sound/soc/codecs/uda134x.c
@@ -452,7 +452,7 @@ SOC_ENUM("PCM Playback De-emphasis", uda134x_mixer_enum[1]),
 SOC_SINGLE("DC Filter Enable Switch", UDA134X_STATUS0, 0, 1, 0),
-static struct snd_soc_dai_ops uda134x_dai_ops = {
+static const struct snd_soc_dai_ops uda134x_dai_ops = {
 	.startup	= uda134x_startup,
 	.shutdown	= uda134x_shutdown,
 	.hw_params	= uda134x_hw_params,
diff --git a/sound/soc/codecs/uda1380.c b/sound/soc/codecs/uda1380.c
index c5ca8cf..6b933ef 100644
--- a/sound/soc/codecs/uda1380.c
+++ b/sound/soc/codecs/uda1380.c
@@ -643,21 +643,21 @@ static int uda1380_set_bias_level(struct snd_soc_codec *codec,
-static struct snd_soc_dai_ops uda1380_dai_ops = {
+static const struct snd_soc_dai_ops uda1380_dai_ops = {
 	.hw_params	= uda1380_pcm_hw_params,
 	.shutdown	= uda1380_pcm_shutdown,
 	.trigger	= uda1380_trigger,
 	.set_fmt	= uda1380_set_dai_fmt_both,
-static struct snd_soc_dai_ops uda1380_dai_ops_playback = {
+static const struct snd_soc_dai_ops uda1380_dai_ops_playback = {
 	.set_fmt	= uda1380_set_dai_fmt_playback,
-static struct snd_soc_dai_ops uda1380_dai_ops_capture = {
+static const struct snd_soc_dai_ops uda1380_dai_ops_capture = {
diff --git a/sound/soc/codecs/wl1273.c b/sound/soc/codecs/wl1273.c
index a854989..9531c35 100644
--- a/sound/soc/codecs/wl1273.c
+++ b/sound/soc/codecs/wl1273.c
@@ -386,7 +386,7 @@ static int wl1273_hw_params(struct snd_pcm_substream *substream,
 	return 0;
-static struct snd_soc_dai_ops wl1273_dai_ops = {
+static const struct snd_soc_dai_ops wl1273_dai_ops = {
 	.startup	= wl1273_startup,
 	.hw_params	= wl1273_hw_params,
diff --git a/sound/soc/codecs/wm5100.c b/sound/soc/codecs/wm5100.c
index f37d67f..6c79d97 100644
--- a/sound/soc/codecs/wm5100.c
+++ b/sound/soc/codecs/wm5100.c
@@ -1661,7 +1661,7 @@ static int wm5100_hw_params(struct snd_pcm_substream *substream,
 	return 0;
-static struct snd_soc_dai_ops wm5100_dai_ops = {
+static const struct snd_soc_dai_ops wm5100_dai_ops = {
 	.set_fmt = wm5100_set_fmt,
 	.hw_params = wm5100_hw_params,
diff --git a/sound/soc/codecs/wm8350.c b/sound/soc/codecs/wm8350.c
index 35f3ad8..3b846c9 100644
--- a/sound/soc/codecs/wm8350.c
+++ b/sound/soc/codecs/wm8350.c
@@ -1511,7 +1511,7 @@ EXPORT_SYMBOL_GPL(wm8350_mic_jack_detect);
-static struct snd_soc_dai_ops wm8350_dai_ops = {
+static const struct snd_soc_dai_ops wm8350_dai_ops = {
 	 .hw_params	= wm8350_pcm_hw_params,
 	 .digital_mute	= wm8350_mute,
 	 .trigger	= wm8350_pcm_trigger,
diff --git a/sound/soc/codecs/wm8400.c b/sound/soc/codecs/wm8400.c
index 585def1..07d84a8 100644
--- a/sound/soc/codecs/wm8400.c
+++ b/sound/soc/codecs/wm8400.c
@@ -1316,7 +1316,7 @@ static int wm8400_set_bias_level(struct snd_soc_codec *codec,
 #define WM8400_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE |\
-static struct snd_soc_dai_ops wm8400_dai_ops = {
+static const struct snd_soc_dai_ops wm8400_dai_ops = {
 	.hw_params = wm8400_hw_params,
 	.digital_mute = wm8400_mute,
 	.set_fmt = wm8400_set_dai_fmt,
diff --git a/sound/soc/codecs/wm8510.c b/sound/soc/codecs/wm8510.c
index 07c9cc7..26571b2 100644
--- a/sound/soc/codecs/wm8510.c
+++ b/sound/soc/codecs/wm8510.c
@@ -509,7 +509,7 @@ static int wm8510_set_bias_level(struct snd_soc_codec *codec,
 #define WM8510_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE |\
-static struct snd_soc_dai_ops wm8510_dai_ops = {
+static const struct snd_soc_dai_ops wm8510_dai_ops = {
 	.hw_params	= wm8510_pcm_hw_params,
 	.digital_mute	= wm8510_mute,
 	.set_fmt	= wm8510_set_dai_fmt,
diff --git a/sound/soc/codecs/wm8523.c b/sound/soc/codecs/wm8523.c
index db7a681..d0ae82d 100644
--- a/sound/soc/codecs/wm8523.c
+++ b/sound/soc/codecs/wm8523.c
@@ -365,7 +365,7 @@ static int wm8523_set_bias_level(struct snd_soc_codec *codec,
 #define WM8523_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE |\
-static struct snd_soc_dai_ops wm8523_dai_ops = {
+static const struct snd_soc_dai_ops wm8523_dai_ops = {
 	.startup	= wm8523_startup,
 	.hw_params	= wm8523_hw_params,
 	.set_sysclk	= wm8523_set_dai_sysclk,
diff --git a/sound/soc/codecs/wm8580.c b/sound/soc/codecs/wm8580.c
index 8212b3c..0aa3e4d 100644
--- a/sound/soc/codecs/wm8580.c
+++ b/sound/soc/codecs/wm8580.c
@@ -776,7 +776,7 @@ static int wm8580_set_bias_level(struct snd_soc_codec *codec,
 #define WM8580_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE |\
-static struct snd_soc_dai_ops wm8580_dai_ops_playback = {
+static const struct snd_soc_dai_ops wm8580_dai_ops_playback = {
 	.set_sysclk	= wm8580_set_sysclk,
 	.hw_params	= wm8580_paif_hw_params,
 	.set_fmt	= wm8580_set_paif_dai_fmt,
@@ -785,7 +785,7 @@ static struct snd_soc_dai_ops wm8580_dai_ops_playback = {
 	.digital_mute	= wm8580_digital_mute,
-static struct snd_soc_dai_ops wm8580_dai_ops_capture = {
+static const struct snd_soc_dai_ops wm8580_dai_ops_capture = {
diff --git a/sound/soc/codecs/wm8711.c b/sound/soc/codecs/wm8711.c
index 076bdb9..a6f1e39 100644
--- a/sound/soc/codecs/wm8711.c
+++ b/sound/soc/codecs/wm8711.c
@@ -318,7 +318,7 @@ static int wm8711_set_bias_level(struct snd_soc_codec *codec,
 #define WM8711_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE |\
-static struct snd_soc_dai_ops wm8711_ops = {
+static const struct snd_soc_dai_ops wm8711_ops = {
 	.prepare = wm8711_pcm_prepare,
 	.hw_params = wm8711_hw_params,
 	.shutdown = wm8711_shutdown,
diff --git a/sound/soc/codecs/wm8728.c b/sound/soc/codecs/wm8728.c
index 04b027e..085c2f8 100644
--- a/sound/soc/codecs/wm8728.c
+++ b/sound/soc/codecs/wm8728.c
@@ -196,7 +196,7 @@ static int wm8728_set_bias_level(struct snd_soc_codec *codec,
 #define WM8728_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE |\
-static struct snd_soc_dai_ops wm8728_dai_ops = {
+static const struct snd_soc_dai_ops wm8728_dai_ops = {
 	.hw_params	= wm8728_hw_params,
 	.digital_mute	= wm8728_mute,
 	.set_fmt	= wm8728_set_dai_fmt,
diff --git a/sound/soc/codecs/wm8731.c b/sound/soc/codecs/wm8731.c
index ca59622..28972d8 100644
--- a/sound/soc/codecs/wm8731.c
+++ b/sound/soc/codecs/wm8731.c
@@ -465,7 +465,7 @@ static int wm8731_set_bias_level(struct snd_soc_codec *codec,
 #define WM8731_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE |\
-static struct snd_soc_dai_ops wm8731_dai_ops = {
+static const struct snd_soc_dai_ops wm8731_dai_ops = {
 	.hw_params	= wm8731_hw_params,
 	.digital_mute	= wm8731_mute,
 	.set_sysclk	= wm8731_set_dai_sysclk,
diff --git a/sound/soc/codecs/wm8737.c b/sound/soc/codecs/wm8737.c
index f6aef58..b7d6615 100644
--- a/sound/soc/codecs/wm8737.c
+++ b/sound/soc/codecs/wm8737.c
@@ -521,7 +521,7 @@ static int wm8737_set_bias_level(struct snd_soc_codec *codec,
 #define WM8737_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE |\
-static struct snd_soc_dai_ops wm8737_dai_ops = {
+static const struct snd_soc_dai_ops wm8737_dai_ops = {
 	.hw_params	= wm8737_hw_params,
 	.set_sysclk	= wm8737_set_dai_sysclk,
 	.set_fmt	= wm8737_set_dai_fmt,
diff --git a/sound/soc/codecs/wm8741.c b/sound/soc/codecs/wm8741.c
index 57ad22a..e51f4f0 100644
--- a/sound/soc/codecs/wm8741.c
+++ b/sound/soc/codecs/wm8741.c
@@ -382,7 +382,7 @@ static int wm8741_set_dai_fmt(struct snd_soc_dai *codec_dai,
 #define WM8741_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE |\
-static struct snd_soc_dai_ops wm8741_dai_ops = {
+static const struct snd_soc_dai_ops wm8741_dai_ops = {
 	.startup	= wm8741_startup,
 	.hw_params	= wm8741_hw_params,
 	.set_sysclk	= wm8741_set_dai_sysclk,
diff --git a/sound/soc/codecs/wm8750.c b/sound/soc/codecs/wm8750.c
index ca75a81..dfb41ad 100644
--- a/sound/soc/codecs/wm8750.c
+++ b/sound/soc/codecs/wm8750.c
@@ -643,7 +643,7 @@ static int wm8750_set_bias_level(struct snd_soc_codec *codec,
 #define WM8750_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE |\
-static struct snd_soc_dai_ops wm8750_dai_ops = {
+static const struct snd_soc_dai_ops wm8750_dai_ops = {
 	.hw_params	= wm8750_pcm_hw_params,
 	.digital_mute	= wm8750_mute,
 	.set_fmt	= wm8750_set_dai_fmt,
diff --git a/sound/soc/codecs/wm8753.c b/sound/soc/codecs/wm8753.c
index 13156c83..fb013b1 100644
--- a/sound/soc/codecs/wm8753.c
+++ b/sound/soc/codecs/wm8753.c
@@ -1315,7 +1315,7 @@ static int wm8753_set_bias_level(struct snd_soc_codec *codec,
  * 3. Voice disabled - HIFI over HIFI
  * 4. Voice disabled - HIFI over HIFI, uses voice DAI LRC for capture
-static struct snd_soc_dai_ops wm8753_dai_ops_hifi_mode = {
+static const struct snd_soc_dai_ops wm8753_dai_ops_hifi_mode = {
 	.hw_params	= wm8753_i2s_hw_params,
 	.digital_mute	= wm8753_mute,
 	.set_fmt	= wm8753_hifi_set_dai_fmt,
@@ -1324,7 +1324,7 @@ static struct snd_soc_dai_ops wm8753_dai_ops_hifi_mode = {
 	.set_sysclk	= wm8753_set_dai_sysclk,
-static struct snd_soc_dai_ops wm8753_dai_ops_voice_mode = {
+static const struct snd_soc_dai_ops wm8753_dai_ops_voice_mode = {
 	.hw_params	= wm8753_pcm_hw_params,
 	.set_fmt	= wm8753_voice_set_dai_fmt,
diff --git a/sound/soc/codecs/wm8770.c b/sound/soc/codecs/wm8770.c
index aa05e65..87957e8 100644
--- a/sound/soc/codecs/wm8770.c
+++ b/sound/soc/codecs/wm8770.c
@@ -528,7 +528,7 @@ static int wm8770_set_bias_level(struct snd_soc_codec *codec,
 #define WM8770_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE | \
-static struct snd_soc_dai_ops wm8770_dai_ops = {
+static const struct snd_soc_dai_ops wm8770_dai_ops = {
 	.digital_mute = wm8770_mute,
 	.hw_params = wm8770_hw_params,
 	.set_fmt = wm8770_set_fmt,
diff --git a/sound/soc/codecs/wm8776.c b/sound/soc/codecs/wm8776.c
index f967c59d..223fc5a 100644
--- a/sound/soc/codecs/wm8776.c
+++ b/sound/soc/codecs/wm8776.c
@@ -327,14 +327,14 @@ static int wm8776_set_bias_level(struct snd_soc_codec *codec,
 #define WM8776_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE |\
-static struct snd_soc_dai_ops wm8776_dac_ops = {
+static const struct snd_soc_dai_ops wm8776_dac_ops = {
 	.digital_mute	= wm8776_mute,
 	.hw_params      = wm8776_hw_params,
 	.set_fmt        = wm8776_set_fmt,
 	.set_sysclk     = wm8776_set_sysclk,
-static struct snd_soc_dai_ops wm8776_adc_ops = {
+static const struct snd_soc_dai_ops wm8776_adc_ops = {
diff --git a/sound/soc/codecs/wm8804.c b/sound/soc/codecs/wm8804.c
index 9ee072b..d99c6a0 100644
--- a/sound/soc/codecs/wm8804.c
+++ b/sound/soc/codecs/wm8804.c
@@ -670,7 +670,7 @@ err_reg_get:
 	return ret;
-static struct snd_soc_dai_ops wm8804_dai_ops = {
+static const struct snd_soc_dai_ops wm8804_dai_ops = {
 	.hw_params = wm8804_hw_params,
 	.set_fmt = wm8804_set_fmt,
 	.set_sysclk = wm8804_set_sysclk,
diff --git a/sound/soc/codecs/wm8900.c b/sound/soc/codecs/wm8900.c
index 17a12c2..a430930 100644
--- a/sound/soc/codecs/wm8900.c
+++ b/sound/soc/codecs/wm8900.c
@@ -987,7 +987,7 @@ static int wm8900_digital_mute(struct snd_soc_dai *codec_dai, int mute)
 	(SNDRV_PCM_FORMAT_S16_LE | SNDRV_PCM_FORMAT_S20_3LE | \
 	 SNDRV_PCM_FORMAT_S24_LE)
-static struct snd_soc_dai_ops wm8900_dai_ops = {
+static const struct snd_soc_dai_ops wm8900_dai_ops = {
 	.hw_params	= wm8900_hw_params,
 	.set_clkdiv	= wm8900_set_dai_clkdiv,
 	.set_pll	= wm8900_set_dai_pll,
diff --git a/sound/soc/codecs/wm8903.c b/sound/soc/codecs/wm8903.c
index 4ad8ebd..812dce9 100644
--- a/sound/soc/codecs/wm8903.c
+++ b/sound/soc/codecs/wm8903.c
@@ -1732,7 +1732,7 @@ static irqreturn_t wm8903_irq(int irq, void *data)
-static struct snd_soc_dai_ops wm8903_dai_ops = {
+static const struct snd_soc_dai_ops wm8903_dai_ops = {
 	.hw_params	= wm8903_hw_params,
 	.digital_mute	= wm8903_digital_mute,
 	.set_fmt	= wm8903_set_dai_fmt,
diff --git a/sound/soc/codecs/wm8904.c b/sound/soc/codecs/wm8904.c
index bb070f83..f0b0c7a 100644
--- a/sound/soc/codecs/wm8904.c
+++ b/sound/soc/codecs/wm8904.c
@@ -2205,7 +2205,7 @@ static int wm8904_set_bias_level(struct snd_soc_codec *codec,
 #define WM8904_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE |\
-static struct snd_soc_dai_ops wm8904_dai_ops = {
+static const struct snd_soc_dai_ops wm8904_dai_ops = {
 	.set_sysclk = wm8904_set_sysclk,
 	.set_fmt = wm8904_set_fmt,
 	.set_tdm_slot = wm8904_set_tdm_slot,
diff --git a/sound/soc/codecs/wm8940.c b/sound/soc/codecs/wm8940.c
index 1b5856b..0dd1e0c 100644
--- a/sound/soc/codecs/wm8940.c
+++ b/sound/soc/codecs/wm8940.c
@@ -644,7 +644,7 @@ static int wm8940_set_dai_clkdiv(struct snd_soc_dai *codec_dai,
-static struct snd_soc_dai_ops wm8940_dai_ops = {
+static const struct snd_soc_dai_ops wm8940_dai_ops = {
 	.hw_params = wm8940_i2s_hw_params,
 	.set_sysclk = wm8940_set_dai_sysclk,
 	.digital_mute = wm8940_mute,
diff --git a/sound/soc/codecs/wm8955.c b/sound/soc/codecs/wm8955.c
index 3c71987..dbf2a83 100644
--- a/sound/soc/codecs/wm8955.c
+++ b/sound/soc/codecs/wm8955.c
@@ -859,7 +859,7 @@ static int wm8955_set_bias_level(struct snd_soc_codec *codec,
 #define WM8955_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE |\
-static struct snd_soc_dai_ops wm8955_dai_ops = {
+static const struct snd_soc_dai_ops wm8955_dai_ops = {
 	.set_sysclk = wm8955_set_sysclk,
 	.set_fmt = wm8955_set_fmt,
 	.hw_params = wm8955_hw_params,
diff --git a/sound/soc/codecs/wm8960.c b/sound/soc/codecs/wm8960.c
index 6e22f9b..06dca88 100644
--- a/sound/soc/codecs/wm8960.c
+++ b/sound/soc/codecs/wm8960.c
@@ -869,7 +869,7 @@ static int wm8960_set_bias_level(struct snd_soc_codec *codec,
-static struct snd_soc_dai_ops wm8960_dai_ops = {
+static const struct snd_soc_dai_ops wm8960_dai_ops = {
 	.hw_params = wm8960_hw_params,
 	.digital_mute = wm8960_mute,
 	.set_fmt = wm8960_set_dai_fmt,
diff --git a/sound/soc/codecs/wm8961.c b/sound/soc/codecs/wm8961.c
index 7f2df7b..783a3d1 100644
--- a/sound/soc/codecs/wm8961.c
+++ b/sound/soc/codecs/wm8961.c
@@ -929,7 +929,7 @@ static int wm8961_set_bias_level(struct snd_soc_codec *codec,
-static struct snd_soc_dai_ops wm8961_dai_ops = {
+static const struct snd_soc_dai_ops wm8961_dai_ops = {
 	.hw_params = wm8961_hw_params,
 	.set_sysclk = wm8961_set_sysclk,
 	.set_fmt = wm8961_set_fmt,
diff --git a/sound/soc/codecs/wm8962.c b/sound/soc/codecs/wm8962.c
index 48b5c95..555311d 100644
--- a/sound/soc/codecs/wm8962.c
+++ b/sound/soc/codecs/wm8962.c
@@ -3503,7 +3503,7 @@ static int wm8962_mute(struct snd_soc_dai *dai, int mute)
 #define WM8962_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE |\
-static struct snd_soc_dai_ops wm8962_dai_ops = {
+static const struct snd_soc_dai_ops wm8962_dai_ops = {
 	.hw_params = wm8962_hw_params,
 	.set_sysclk = wm8962_set_dai_sysclk,
 	.set_fmt = wm8962_set_dai_fmt,
diff --git a/sound/soc/codecs/wm8971.c b/sound/soc/codecs/wm8971.c
index 3a06a95..98bfbdd 100644
--- a/sound/soc/codecs/wm8971.c
+++ b/sound/soc/codecs/wm8971.c
@@ -567,7 +567,7 @@ static int wm8971_set_bias_level(struct snd_soc_codec *codec,
 #define WM8971_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE |\
-static struct snd_soc_dai_ops wm8971_dai_ops = {
+static const struct snd_soc_dai_ops wm8971_dai_ops = {
 	.hw_params	= wm8971_pcm_hw_params,
 	.digital_mute	= wm8971_mute,
 	.set_fmt	= wm8971_set_dai_fmt,
diff --git a/sound/soc/codecs/wm8974.c b/sound/soc/codecs/wm8974.c
index 7bd35b8..16569c7 100644
--- a/sound/soc/codecs/wm8974.c
+++ b/sound/soc/codecs/wm8974.c
@@ -557,7 +557,7 @@ static int wm8974_set_bias_level(struct snd_soc_codec *codec,
 #define WM8974_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE |\
-static struct snd_soc_dai_ops wm8974_ops = {
+static const struct snd_soc_dai_ops wm8974_ops = {
 	.hw_params = wm8974_pcm_hw_params,
 	.digital_mute = wm8974_mute,
 	.set_fmt = wm8974_set_dai_fmt,
diff --git a/sound/soc/codecs/wm8978.c b/sound/soc/codecs/wm8978.c
index 41ca4d9..517bb22 100644
--- a/sound/soc/codecs/wm8978.c
+++ b/sound/soc/codecs/wm8978.c
@@ -865,7 +865,7 @@ static int wm8978_set_bias_level(struct snd_soc_codec *codec,
 #define WM8978_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE | \
-static struct snd_soc_dai_ops wm8978_dai_ops = {
+static const struct snd_soc_dai_ops wm8978_dai_ops = {
 	.hw_params	= wm8978_hw_params,
 	.digital_mute	= wm8978_mute,
 	.set_fmt	= wm8978_set_dai_fmt,
diff --git a/sound/soc/codecs/wm8983.c b/sound/soc/codecs/wm8983.c
index 58e067b..362298c 100644
--- a/sound/soc/codecs/wm8983.c
+++ b/sound/soc/codecs/wm8983.c
@@ -1035,7 +1035,7 @@ static int wm8983_probe(struct snd_soc_codec *codec)
 	return 0;
-static struct snd_soc_dai_ops wm8983_dai_ops = {
+static const struct snd_soc_dai_ops wm8983_dai_ops = {
 	.digital_mute = wm8983_dac_mute,
 	.hw_params = wm8983_hw_params,
 	.set_fmt = wm8983_set_fmt,
diff --git a/sound/soc/codecs/wm8985.c b/sound/soc/codecs/wm8985.c
index 36c4ee0..9e4481b 100644
--- a/sound/soc/codecs/wm8985.c
+++ b/sound/soc/codecs/wm8985.c
@@ -1031,7 +1031,7 @@ err_reg_get:
 	return ret;
-static struct snd_soc_dai_ops wm8985_dai_ops = {
+static const struct snd_soc_dai_ops wm8985_dai_ops = {
 	.digital_mute = wm8985_dac_mute,
 	.hw_params = wm8985_hw_params,
 	.set_fmt = wm8985_set_fmt,
diff --git a/sound/soc/codecs/wm8988.c b/sound/soc/codecs/wm8988.c
index 514189d..9d83bed5 100644
--- a/sound/soc/codecs/wm8988.c
+++ b/sound/soc/codecs/wm8988.c
@@ -701,7 +701,7 @@ static int wm8988_set_bias_level(struct snd_soc_codec *codec,
 #define WM8988_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE |\
-static struct snd_soc_dai_ops wm8988_ops = {
+static const struct snd_soc_dai_ops wm8988_ops = {
 	.startup = wm8988_pcm_startup,
 	.hw_params = wm8988_pcm_hw_params,
 	.set_fmt = wm8988_set_dai_fmt,
diff --git a/sound/soc/codecs/wm8990.c b/sound/soc/codecs/wm8990.c
index d4cbec6..61c620e 100644
--- a/sound/soc/codecs/wm8990.c
+++ b/sound/soc/codecs/wm8990.c
@@ -1287,7 +1287,7 @@ static int wm8990_set_bias_level(struct snd_soc_codec *codec,
  * 1. ADC/DAC on Primary Interface
  * 2. ADC on Primary Interface/DAC on secondary
-static struct snd_soc_dai_ops wm8990_dai_ops = {
+static const struct snd_soc_dai_ops wm8990_dai_ops = {
 	.hw_params	= wm8990_hw_params,
 	.digital_mute	= wm8990_mute,
 	.set_fmt	= wm8990_set_dai_fmt,
diff --git a/sound/soc/codecs/wm8991.c b/sound/soc/codecs/wm8991.c
index 1d46d59..ac957ec 100644
--- a/sound/soc/codecs/wm8991.c
+++ b/sound/soc/codecs/wm8991.c
@@ -1311,7 +1311,7 @@ static int wm8991_probe(struct snd_soc_codec *codec)
 #define WM8991_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE |\
-static struct snd_soc_dai_ops wm8991_ops = {
+static const struct snd_soc_dai_ops wm8991_ops = {
 	.hw_params = wm8991_hw_params,
 	.digital_mute = wm8991_mute,
 	.set_fmt = wm8991_set_dai_fmt,
diff --git a/sound/soc/codecs/wm8993.c b/sound/soc/codecs/wm8993.c
index d1a142f4..780c24c 100644
--- a/sound/soc/codecs/wm8993.c
+++ b/sound/soc/codecs/wm8993.c
@@ -1394,7 +1394,7 @@ out:
 	return 0;
-static struct snd_soc_dai_ops wm8993_ops = {
+static const struct snd_soc_dai_ops wm8993_ops = {
 	.set_sysclk = wm8993_set_sysclk,
 	.set_fmt = wm8993_set_dai_fmt,
 	.hw_params = wm8993_hw_params,
diff --git a/sound/soc/codecs/wm8994.c b/sound/soc/codecs/wm8994.c
index 9c982e4..73db980 100644
--- a/sound/soc/codecs/wm8994.c
+++ b/sound/soc/codecs/wm8994.c
@@ -2531,7 +2531,7 @@ static int wm8994_aif2_probe(struct snd_soc_dai *dai)
 #define WM8994_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE |\
-static struct snd_soc_dai_ops wm8994_aif1_dai_ops = {
+static const struct snd_soc_dai_ops wm8994_aif1_dai_ops = {
 	.set_sysclk	= wm8994_set_dai_sysclk,
 	.set_fmt	= wm8994_set_dai_fmt,
 	.hw_params	= wm8994_hw_params,
@@ -2541,7 +2541,7 @@ static struct snd_soc_dai_ops wm8994_aif1_dai_ops = {
 	.set_tristate	= wm8994_set_tristate,
-static struct snd_soc_dai_ops wm8994_aif2_dai_ops = {
+static const struct snd_soc_dai_ops wm8994_aif2_dai_ops = {
@@ -2551,7 +2551,7 @@ static struct snd_soc_dai_ops wm8994_aif2_dai_ops = {
-static struct snd_soc_dai_ops wm8994_aif3_dai_ops = {
+static const struct snd_soc_dai_ops wm8994_aif3_dai_ops = {
 	.hw_params	= wm8994_aif3_hw_params,
diff --git a/sound/soc/codecs/wm8995.c b/sound/soc/codecs/wm8995.c
index 3774acb..8f6a36d 100644
--- a/sound/soc/codecs/wm8995.c
+++ b/sound/soc/codecs/wm8995.c
@@ -2155,7 +2155,7 @@ err_reg_get:
 #define WM8995_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE |\
-static struct snd_soc_dai_ops wm8995_aif1_dai_ops = {
+static const struct snd_soc_dai_ops wm8995_aif1_dai_ops = {
 	.set_sysclk = wm8995_set_dai_sysclk,
 	.set_fmt = wm8995_set_dai_fmt,
 	.hw_params = wm8995_hw_params,
@@ -2164,7 +2164,7 @@ static struct snd_soc_dai_ops wm8995_aif1_dai_ops = {
 	.set_tristate = wm8995_set_tristate,
-static struct snd_soc_dai_ops wm8995_aif2_dai_ops = {
+static const struct snd_soc_dai_ops wm8995_aif2_dai_ops = {
@@ -2173,7 +2173,7 @@ static struct snd_soc_dai_ops wm8995_aif2_dai_ops = {
-static struct snd_soc_dai_ops wm8995_aif3_dai_ops = {
+static const struct snd_soc_dai_ops wm8995_aif3_dai_ops = {
diff --git a/sound/soc/codecs/wm8996.c b/sound/soc/codecs/wm8996.c
index fd5bb1a..304a0e5 100644
--- a/sound/soc/codecs/wm8996.c
+++ b/sound/soc/codecs/wm8996.c
@@ -3052,7 +3052,7 @@ static struct snd_soc_codec_driver soc_codec_dev_wm8996 = {
 			SNDRV_PCM_FMTBIT_S20_3LE | SNDRV_PCM_FMTBIT_S24_LE |\
-static struct snd_soc_dai_ops wm8996_dai_ops = {
+static const struct snd_soc_dai_ops wm8996_dai_ops = {
 	.set_fmt = wm8996_set_fmt,
 	.hw_params = wm8996_hw_params,
 	.set_sysclk = wm8996_set_sysclk,
diff --git a/sound/soc/codecs/wm9081.c b/sound/soc/codecs/wm9081.c
index f7c0738..48bf80b 100644
--- a/sound/soc/codecs/wm9081.c
+++ b/sound/soc/codecs/wm9081.c
@@ -1234,7 +1234,7 @@ static int wm9081_set_tdm_slot(struct snd_soc_dai *dai,
-static struct snd_soc_dai_ops wm9081_dai_ops = {
+static const struct snd_soc_dai_ops wm9081_dai_ops = {
 	.hw_params = wm9081_hw_params,
 	.set_fmt = wm9081_set_dai_fmt,
 	.digital_mute = wm9081_digital_mute,
diff --git a/sound/soc/codecs/wm9705.c b/sound/soc/codecs/wm9705.c
index 646b58d..edf6032 100644
--- a/sound/soc/codecs/wm9705.c
+++ b/sound/soc/codecs/wm9705.c
@@ -258,7 +258,7 @@ static int ac97_prepare(struct snd_pcm_substream *substream,
 			SNDRV_PCM_RATE_32000 | SNDRV_PCM_RATE_44100 | \
-static struct snd_soc_dai_ops wm9705_dai_ops = {
+static const struct snd_soc_dai_ops wm9705_dai_ops = {
diff --git a/sound/soc/codecs/wm9712.c b/sound/soc/codecs/wm9712.c
index 90117f8..fd18127 100644
--- a/sound/soc/codecs/wm9712.c
+++ b/sound/soc/codecs/wm9712.c
@@ -505,11 +505,11 @@ static int ac97_aux_prepare(struct snd_pcm_substream *substream,
-static struct snd_soc_dai_ops wm9712_dai_ops_hifi = {
+static const struct snd_soc_dai_ops wm9712_dai_ops_hifi = {
-static struct snd_soc_dai_ops wm9712_dai_ops_aux = {
+static const struct snd_soc_dai_ops wm9712_dai_ops_aux = {
 	.prepare	= ac97_aux_prepare,
diff --git a/sound/soc/codecs/wm9713.c b/sound/soc/codecs/wm9713.c
index 7167cb6..09360b6 100644
--- a/sound/soc/codecs/wm9713.c
+++ b/sound/soc/codecs/wm9713.c
@@ -1026,19 +1026,19 @@ static int ac97_aux_prepare(struct snd_pcm_substream *substream,
-static struct snd_soc_dai_ops wm9713_dai_ops_hifi = {
+static const struct snd_soc_dai_ops wm9713_dai_ops_hifi = {
 	.prepare	= ac97_hifi_prepare,
 	.set_clkdiv	= wm9713_set_dai_clkdiv,
 	.set_pll	= wm9713_set_dai_pll,
-static struct snd_soc_dai_ops wm9713_dai_ops_aux = {
+static const struct snd_soc_dai_ops wm9713_dai_ops_aux = {
-static struct snd_soc_dai_ops wm9713_dai_ops_voice = {
+static const struct snd_soc_dai_ops wm9713_dai_ops_voice = {
 	.hw_params	= wm9713_pcm_hw_params,
diff --git a/sound/soc/davinci/davinci-i2s.c b/sound/soc/davinci/davinci-i2s.c
index 300e121..f3d5ae1 100644
--- a/sound/soc/davinci/davinci-i2s.c
+++ b/sound/soc/davinci/davinci-i2s.c
@@ -620,7 +620,7 @@ static void davinci_i2s_shutdown(struct snd_pcm_substream *substream,
 #define DAVINCI_I2S_RATES	SNDRV_PCM_RATE_8000_96000
-static struct snd_soc_dai_ops davinci_i2s_dai_ops = {
+static const struct snd_soc_dai_ops davinci_i2s_dai_ops = {
 	.startup	= davinci_i2s_startup,
 	.shutdown	= davinci_i2s_shutdown,
 	.prepare	= davinci_i2s_prepare,
diff --git a/sound/soc/davinci/davinci-mcasp.c b/sound/soc/davinci/davinci-mcasp.c
index 7173df2..03cea9d 100644
--- a/sound/soc/davinci/davinci-mcasp.c
+++ b/sound/soc/davinci/davinci-mcasp.c
@@ -813,7 +813,7 @@ static int davinci_mcasp_startup(struct snd_pcm_substream *substream,
 	return 0;
-static struct snd_soc_dai_ops davinci_mcasp_dai_ops = {
+static const struct snd_soc_dai_ops davinci_mcasp_dai_ops = {
 	.startup	= davinci_mcasp_startup,
 	.trigger	= davinci_mcasp_trigger,
 	.hw_params	= davinci_mcasp_hw_params,
diff --git a/sound/soc/davinci/davinci-vcif.c b/sound/soc/davinci/davinci-vcif.c
index 1f11525..dae96b8 100644
--- a/sound/soc/davinci/davinci-vcif.c
+++ b/sound/soc/davinci/davinci-vcif.c
@@ -183,7 +183,7 @@ static int davinci_vcif_startup(struct snd_pcm_substream *substream,
 #define DAVINCI_VCIF_RATES	SNDRV_PCM_RATE_8000_48000
-static struct snd_soc_dai_ops davinci_vcif_dai_ops = {
+static const struct snd_soc_dai_ops davinci_vcif_dai_ops = {
 	.startup	= davinci_vcif_startup,
 	.trigger	= davinci_vcif_trigger,
 	.hw_params	= davinci_vcif_hw_params,
diff --git a/sound/soc/ep93xx/ep93xx-ac97.c b/sound/soc/ep93xx/ep93xx-ac97.c
index 3cd6158..c423d12 100644
--- a/sound/soc/ep93xx/ep93xx-ac97.c
+++ b/sound/soc/ep93xx/ep93xx-ac97.c
@@ -330,7 +330,7 @@ static int ep93xx_ac97_startup(struct snd_pcm_substream *substream,
 	return 0;
-static struct snd_soc_dai_ops ep93xx_ac97_dai_ops = {
+static const struct snd_soc_dai_ops ep93xx_ac97_dai_ops = {
 	.startup	= ep93xx_ac97_startup,
 	.trigger	= ep93xx_ac97_trigger,
diff --git a/sound/soc/ep93xx/ep93xx-i2s.c b/sound/soc/ep93xx/ep93xx-i2s.c
index 099614e..3dba128 100644
--- a/sound/soc/ep93xx/ep93xx-i2s.c
+++ b/sound/soc/ep93xx/ep93xx-i2s.c
@@ -338,7 +338,7 @@ static int ep93xx_i2s_resume(struct snd_soc_dai *dai)
 #define ep93xx_i2s_resume	NULL
 #endif
-static struct snd_soc_dai_ops ep93xx_i2s_dai_ops = {
+static const struct snd_soc_dai_ops ep93xx_i2s_dai_ops = {
 	.startup	= ep93xx_i2s_startup,
 	.shutdown	= ep93xx_i2s_shutdown,
 	.hw_params	= ep93xx_i2s_hw_params,
diff --git a/sound/soc/fsl/fsl_ssi.c b/sound/soc/fsl/fsl_ssi.c
index 83c4bd5..17d857e 100644
--- a/sound/soc/fsl/fsl_ssi.c
+++ b/sound/soc/fsl/fsl_ssi.c
@@ -514,7 +514,7 @@ static void fsl_ssi_shutdown(struct snd_pcm_substream *substream,
-static struct snd_soc_dai_ops fsl_ssi_dai_ops = {
+static const struct snd_soc_dai_ops fsl_ssi_dai_ops = {
 	.startup	= fsl_ssi_startup,
 	.hw_params	= fsl_ssi_hw_params,
 	.shutdown	= fsl_ssi_shutdown,
diff --git a/sound/soc/fsl/mpc5200_psc_ac97.c b/sound/soc/fsl/mpc5200_psc_ac97.c
index ad36b09..2fb388f 100644
--- a/sound/soc/fsl/mpc5200_psc_ac97.c
+++ b/sound/soc/fsl/mpc5200_psc_ac97.c
@@ -226,12 +226,12 @@ static int psc_ac97_probe(struct snd_soc_dai *cpu_dai)
  * psc_ac97_dai_template: template CPU Digital Audio Interface
-static struct snd_soc_dai_ops psc_ac97_analog_ops = {
+static const struct snd_soc_dai_ops psc_ac97_analog_ops = {
 	.hw_params	= psc_ac97_hw_analog_params,
 	.trigger	= psc_ac97_trigger,
-static struct snd_soc_dai_ops psc_ac97_digital_ops = {
+static const struct snd_soc_dai_ops psc_ac97_digital_ops = {
 	.hw_params	= psc_ac97_hw_digital_params,
diff --git a/sound/soc/fsl/mpc5200_psc_i2s.c b/sound/soc/fsl/mpc5200_psc_i2s.c
index 87cf2a5..e77a1f2 100644
--- a/sound/soc/fsl/mpc5200_psc_i2s.c
+++ b/sound/soc/fsl/mpc5200_psc_i2s.c
@@ -123,7 +123,7 @@ static int psc_i2s_set_fmt(struct snd_soc_dai *cpu_dai, unsigned int format)
  * psc_i2s_dai_template: template CPU Digital Audio Interface
-static struct snd_soc_dai_ops psc_i2s_dai_ops = {
+static const struct snd_soc_dai_ops psc_i2s_dai_ops = {
 	.hw_params	= psc_i2s_hw_params,
 	.set_sysclk	= psc_i2s_set_sysclk,
 	.set_fmt	= psc_i2s_set_fmt,
diff --git a/sound/soc/imx/imx-ssi.c b/sound/soc/imx/imx-ssi.c
index 4c05e2b..eed7041 100644
--- a/sound/soc/imx/imx-ssi.c
+++ b/sound/soc/imx/imx-ssi.c
@@ -342,7 +342,7 @@ static int imx_ssi_trigger(struct snd_pcm_substream *substream, int cmd,
 	return 0;
-static struct snd_soc_dai_ops imx_ssi_pcm_dai_ops = {
+static const struct snd_soc_dai_ops imx_ssi_pcm_dai_ops = {
 	.hw_params	= imx_ssi_hw_params,
 	.set_fmt	= imx_ssi_set_dai_fmt,
 	.set_clkdiv	= imx_ssi_set_dai_clkdiv,
diff --git a/sound/soc/jz4740/jz4740-i2s.c b/sound/soc/jz4740/jz4740-i2s.c
index cd22a54..91255c6 100644
--- a/sound/soc/jz4740/jz4740-i2s.c
+++ b/sound/soc/jz4740/jz4740-i2s.c
@@ -392,7 +392,7 @@ static int jz4740_i2s_dai_remove(struct snd_soc_dai *dai)
 	return 0;
-static struct snd_soc_dai_ops jz4740_i2s_dai_ops = {
+static const struct snd_soc_dai_ops jz4740_i2s_dai_ops = {
 	.startup = jz4740_i2s_startup,
 	.shutdown = jz4740_i2s_shutdown,
 	.trigger = jz4740_i2s_trigger,
diff --git a/sound/soc/kirkwood/kirkwood-i2s.c b/sound/soc/kirkwood/kirkwood-i2s.c
index 715e841..2b212dc 100644
--- a/sound/soc/kirkwood/kirkwood-i2s.c
+++ b/sound/soc/kirkwood/kirkwood-i2s.c
@@ -373,7 +373,7 @@ static int kirkwood_i2s_remove(struct snd_soc_dai *dai)
 	return 0;
-static struct snd_soc_dai_ops kirkwood_i2s_dai_ops = {
+static const struct snd_soc_dai_ops kirkwood_i2s_dai_ops = {
 	.startup	= kirkwood_i2s_startup,
 	.trigger	= kirkwood_i2s_trigger,
 	.hw_params      = kirkwood_i2s_hw_params,
diff --git a/sound/soc/mxs/mxs-saif.c b/sound/soc/mxs/mxs-saif.c
index 76dc74d..46d76b5 100644
--- a/sound/soc/mxs/mxs-saif.c
+++ b/sound/soc/mxs/mxs-saif.c
@@ -550,7 +550,7 @@ static int mxs_saif_trigger(struct snd_pcm_substream *substream, int cmd,
-static struct snd_soc_dai_ops mxs_saif_dai_ops = {
+static const struct snd_soc_dai_ops mxs_saif_dai_ops = {
 	.startup = mxs_saif_startup,
 	.trigger = mxs_saif_trigger,
 	.prepare = mxs_saif_prepare,
diff --git a/sound/soc/nuc900/nuc900-ac97.c b/sound/soc/nuc900/nuc900-ac97.c
index 9c0edad..7544d24 100644
--- a/sound/soc/nuc900/nuc900-ac97.c
+++ b/sound/soc/nuc900/nuc900-ac97.c
@@ -291,7 +291,7 @@ static int nuc900_ac97_remove(struct snd_soc_dai *dai)
 	return 0;
-static struct snd_soc_dai_ops nuc900_ac97_dai_ops = {
+static const struct snd_soc_dai_ops nuc900_ac97_dai_ops = {
 	.trigger	= nuc900_ac97_trigger,
diff --git a/sound/soc/omap/ams-delta.c b/sound/soc/omap/ams-delta.c
index ccb8a6a..a04a433 100644
--- a/sound/soc/omap/ams-delta.c
+++ b/sound/soc/omap/ams-delta.c
@@ -474,7 +474,7 @@ static int ams_delta_digital_mute(struct snd_soc_dai *dai, int mute)
 /* Our codec DAI probably doesn't have its own .ops structure */
-static struct snd_soc_dai_ops ams_delta_dai_ops = {
+static const struct snd_soc_dai_ops ams_delta_dai_ops = {
 	.digital_mute = ams_delta_digital_mute,
diff --git a/sound/soc/omap/omap-hdmi.c b/sound/soc/omap/omap-hdmi.c
index 36c6eae..9bb1cf8 100644
--- a/sound/soc/omap/omap-hdmi.c
+++ b/sound/soc/omap/omap-hdmi.c
@@ -83,7 +83,7 @@ static int omap_hdmi_dai_hw_params(struct snd_pcm_substream *substream,
 	return err;
-static struct snd_soc_dai_ops omap_hdmi_dai_ops = {
+static const struct snd_soc_dai_ops omap_hdmi_dai_ops = {
 	.startup	= omap_hdmi_dai_startup,
 	.hw_params	= omap_hdmi_dai_hw_params,
diff --git a/sound/soc/omap/omap-mcbsp.c b/sound/soc/omap/omap-mcbsp.c
index 4314647..d91e6ef 100644
--- a/sound/soc/omap/omap-mcbsp.c
+++ b/sound/soc/omap/omap-mcbsp.c
@@ -599,7 +599,7 @@ static int omap_mcbsp_dai_set_dai_sysclk(struct snd_soc_dai *cpu_dai,
 	return err;
-static struct snd_soc_dai_ops mcbsp_dai_ops = {
+static const struct snd_soc_dai_ops mcbsp_dai_ops = {
 	.startup	= omap_mcbsp_dai_startup,
 	.shutdown	= omap_mcbsp_dai_shutdown,
 	.trigger	= omap_mcbsp_dai_trigger,
diff --git a/sound/soc/omap/omap-mcpdm.c b/sound/soc/omap/omap-mcpdm.c
index 41d1706..cc8ceff 100644
--- a/sound/soc/omap/omap-mcpdm.c
+++ b/sound/soc/omap/omap-mcpdm.c
@@ -367,7 +367,7 @@ static int omap_mcpdm_prepare(struct snd_pcm_substream *substream,
 	return 0;
-static struct snd_soc_dai_ops omap_mcpdm_dai_ops = {
+static const struct snd_soc_dai_ops omap_mcpdm_dai_ops = {
 	.startup	= omap_mcpdm_dai_startup,
 	.shutdown	= omap_mcpdm_dai_shutdown,
 	.hw_params	= omap_mcpdm_dai_hw_params,
diff --git a/sound/soc/pxa/pxa-ssp.c b/sound/soc/pxa/pxa-ssp.c
index 8ad93ee..9c9a51e 100644
--- a/sound/soc/pxa/pxa-ssp.c
+++ b/sound/soc/pxa/pxa-ssp.c
@@ -771,7 +771,7 @@ static int pxa_ssp_remove(struct snd_soc_dai *dai)
-static struct snd_soc_dai_ops pxa_ssp_dai_ops = {
+static const struct snd_soc_dai_ops pxa_ssp_dai_ops = {
 	.startup	= pxa_ssp_startup,
 	.shutdown	= pxa_ssp_shutdown,
 	.trigger	= pxa_ssp_trigger,
diff --git a/sound/soc/pxa/pxa2xx-ac97.c b/sound/soc/pxa/pxa2xx-ac97.c
index ac51c6d..3fec2f3 100644
--- a/sound/soc/pxa/pxa2xx-ac97.c
+++ b/sound/soc/pxa/pxa2xx-ac97.c
@@ -163,15 +163,15 @@ static int pxa2xx_ac97_hw_mic_params(struct snd_pcm_substream *substream,
 		SNDRV_PCM_RATE_16000 | SNDRV_PCM_RATE_22050 | SNDRV_PCM_RATE_44100 | \
-static struct snd_soc_dai_ops pxa_ac97_hifi_dai_ops = {
+static const struct snd_soc_dai_ops pxa_ac97_hifi_dai_ops = {
 	.hw_params	= pxa2xx_ac97_hw_params,
-static struct snd_soc_dai_ops pxa_ac97_aux_dai_ops = {
+static const struct snd_soc_dai_ops pxa_ac97_aux_dai_ops = {
 	.hw_params	= pxa2xx_ac97_hw_aux_params,
-static struct snd_soc_dai_ops pxa_ac97_mic_dai_ops = {
+static const struct snd_soc_dai_ops pxa_ac97_mic_dai_ops = {
 	.hw_params	= pxa2xx_ac97_hw_mic_params,
diff --git a/sound/soc/pxa/pxa2xx-i2s.c b/sound/soc/pxa/pxa2xx-i2s.c
index 11be595..609abd5 100644
--- a/sound/soc/pxa/pxa2xx-i2s.c
+++ b/sound/soc/pxa/pxa2xx-i2s.c
@@ -331,7 +331,7 @@ static int  pxa2xx_i2s_remove(struct snd_soc_dai *dai)
 		SNDRV_PCM_RATE_48000 | SNDRV_PCM_RATE_96000)
-static struct snd_soc_dai_ops pxa_i2s_dai_ops = {
+static const struct snd_soc_dai_ops pxa_i2s_dai_ops = {
 	.startup	= pxa2xx_i2s_startup,
 	.shutdown	= pxa2xx_i2s_shutdown,
 	.trigger	= pxa2xx_i2s_trigger,
diff --git a/sound/soc/s6000/s6000-i2s.c b/sound/soc/s6000/s6000-i2s.c
index 3052f64..13716a9 100644
--- a/sound/soc/s6000/s6000-i2s.c
+++ b/sound/soc/s6000/s6000-i2s.c
@@ -409,7 +409,7 @@ static int s6000_i2s_dai_probe(struct snd_soc_dai *dai)
 			 SNDRV_PCM_RATE_8000_192000)
 #define S6000_I2S_FORMATS (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S32_LE)
-static struct snd_soc_dai_ops s6000_i2s_dai_ops = {
+static const struct snd_soc_dai_ops s6000_i2s_dai_ops = {
 	.set_fmt = s6000_i2s_set_dai_fmt,
 	.set_clkdiv = s6000_i2s_set_clkdiv,
 	.hw_params = s6000_i2s_hw_params,
diff --git a/sound/soc/samsung/ac97.c b/sound/soc/samsung/ac97.c
index 16521e3..09035af 100644
--- a/sound/soc/samsung/ac97.c
+++ b/sound/soc/samsung/ac97.c
@@ -329,12 +329,12 @@ static int s3c_ac97_mic_trigger(struct snd_pcm_substream *substream,
 	return 0;
-static struct snd_soc_dai_ops s3c_ac97_dai_ops = {
+static const struct snd_soc_dai_ops s3c_ac97_dai_ops = {
 	.hw_params	= s3c_ac97_hw_params,
 	.trigger	= s3c_ac97_trigger,
-static struct snd_soc_dai_ops s3c_ac97_mic_dai_ops = {
+static const struct snd_soc_dai_ops s3c_ac97_mic_dai_ops = {
 	.hw_params	= s3c_ac97_hw_mic_params,
 	.trigger	= s3c_ac97_mic_trigger,
diff --git a/sound/soc/samsung/i2s.c b/sound/soc/samsung/i2s.c
index bff42bf..03ee8ce 100644
--- a/sound/soc/samsung/i2s.c
+++ b/sound/soc/samsung/i2s.c
@@ -923,7 +923,7 @@ static int samsung_i2s_dai_remove(struct snd_soc_dai *dai)
 	return 0;
-static struct snd_soc_dai_ops samsung_i2s_dai_ops = {
+static const struct snd_soc_dai_ops samsung_i2s_dai_ops = {
 	.trigger = i2s_trigger,
 	.hw_params = i2s_hw_params,
 	.set_fmt = i2s_set_fmt,
diff --git a/sound/soc/samsung/pcm.c b/sound/soc/samsung/pcm.c
index 05a47cf..2df2762 100644
--- a/sound/soc/samsung/pcm.c
+++ b/sound/soc/samsung/pcm.c
@@ -452,7 +452,7 @@ static int s3c_pcm_set_sysclk(struct snd_soc_dai *cpu_dai,
 	return 0;
-static struct snd_soc_dai_ops s3c_pcm_dai_ops = {
+static const struct snd_soc_dai_ops s3c_pcm_dai_ops = {
 	.set_sysclk	= s3c_pcm_set_sysclk,
 	.set_clkdiv	= s3c_pcm_set_clkdiv,
 	.trigger	= s3c_pcm_trigger,
diff --git a/sound/soc/samsung/s3c2412-i2s.c b/sound/soc/samsung/s3c2412-i2s.c
index 7bbec25..545773d 100644
--- a/sound/soc/samsung/s3c2412-i2s.c
+++ b/sound/soc/samsung/s3c2412-i2s.c
@@ -142,7 +142,7 @@ static int s3c2412_i2s_hw_params(struct snd_pcm_substream *substream,
 	SNDRV_PCM_RATE_22050 | SNDRV_PCM_RATE_32000 | SNDRV_PCM_RATE_44100 | \
 	SNDRV_PCM_RATE_48000 | SNDRV_PCM_RATE_88200 | SNDRV_PCM_RATE_96000)
-static struct snd_soc_dai_ops s3c2412_i2s_dai_ops = {
+static const struct snd_soc_dai_ops s3c2412_i2s_dai_ops = {
 	.hw_params	= s3c2412_i2s_hw_params,
diff --git a/sound/soc/samsung/s3c24xx-i2s.c b/sound/soc/samsung/s3c24xx-i2s.c
index 558c64b..2a98bed 100644
--- a/sound/soc/samsung/s3c24xx-i2s.c
+++ b/sound/soc/samsung/s3c24xx-i2s.c
@@ -444,7 +444,7 @@ static int s3c24xx_i2s_resume(struct snd_soc_dai *cpu_dai)
-static struct snd_soc_dai_ops s3c24xx_i2s_dai_ops = {
+static const struct snd_soc_dai_ops s3c24xx_i2s_dai_ops = {
 	.trigger	= s3c24xx_i2s_trigger,
 	.hw_params	= s3c24xx_i2s_hw_params,
 	.set_fmt	= s3c24xx_i2s_set_fmt,
diff --git a/sound/soc/samsung/spdif.c b/sound/soc/samsung/spdif.c
index 468cff1..a1fee1a 100644
--- a/sound/soc/samsung/spdif.c
+++ b/sound/soc/samsung/spdif.c
@@ -334,7 +334,7 @@ static int spdif_resume(struct snd_soc_dai *cpu_dai)
 #define spdif_resume NULL
 #endif
-static struct snd_soc_dai_ops spdif_dai_ops = {
+static const struct snd_soc_dai_ops spdif_dai_ops = {
 	.set_sysclk	= spdif_set_sysclk,
 	.trigger	= spdif_trigger,
 	.hw_params	= spdif_hw_params,
diff --git a/sound/soc/sh/fsi.c b/sound/soc/sh/fsi.c
index 99ed610..aa30330 100644
--- a/sound/soc/sh/fsi.c
+++ b/sound/soc/sh/fsi.c
@@ -1096,7 +1096,7 @@ static int fsi_dai_hw_params(struct snd_pcm_substream *substream,
 	return ret;
-static struct snd_soc_dai_ops fsi_dai_ops = {
+static const struct snd_soc_dai_ops fsi_dai_ops = {
 	.startup	= fsi_dai_startup,
 	.shutdown	= fsi_dai_shutdown,
 	.trigger	= fsi_dai_trigger,
diff --git a/sound/soc/sh/hac.c b/sound/soc/sh/hac.c
index c87e3ff..a1f307b 100644
--- a/sound/soc/sh/hac.c
+++ b/sound/soc/sh/hac.c
@@ -266,7 +266,7 @@ static int hac_hw_params(struct snd_pcm_substream *substream,
 #define AC97_FMTS	\
-static struct snd_soc_dai_ops hac_dai_ops = {
+static const struct snd_soc_dai_ops hac_dai_ops = {
 	.hw_params	= hac_hw_params,
diff --git a/sound/soc/sh/siu_dai.c b/sound/soc/sh/siu_dai.c
index edacfeb..93dea49 100644
--- a/sound/soc/sh/siu_dai.c
+++ b/sound/soc/sh/siu_dai.c
@@ -707,7 +707,7 @@ epclkget:
 	return ret;
-static struct snd_soc_dai_ops siu_dai_ops = {
+static const struct snd_soc_dai_ops siu_dai_ops = {
 	.startup	= siu_dai_startup,
 	.shutdown	= siu_dai_shutdown,
 	.prepare	= siu_dai_prepare,
diff --git a/sound/soc/sh/ssi.c b/sound/soc/sh/ssi.c
index e0c621c..1fda16a 100644
--- a/sound/soc/sh/ssi.c
+++ b/sound/soc/sh/ssi.c
@@ -332,7 +332,7 @@ static int ssi_set_fmt(struct snd_soc_dai *dai, unsigned int fmt)
 	 SNDRV_PCM_FMTBIT_S24_3LE | SNDRV_PCM_FMTBIT_U24_3LE |	\
 	 SNDRV_PCM_FMTBIT_S32_LE  | SNDRV_PCM_FMTBIT_U32_LE)
-static struct snd_soc_dai_ops ssi_dai_ops = {
+static const struct snd_soc_dai_ops ssi_dai_ops = {
 	.startup	= ssi_startup,
 	.shutdown	= ssi_shutdown,
 	.trigger	= ssi_trigger,
diff --git a/sound/soc/soc-core.c b/sound/soc/soc-core.c
index a5d3685..bf41d90 100644
--- a/sound/soc/soc-core.c
+++ b/sound/soc/soc-core.c
@@ -735,7 +735,7 @@ EXPORT_SYMBOL_GPL(snd_soc_resume);
 #define snd_soc_resume NULL
 #endif
-static struct snd_soc_dai_ops null_dai_ops = {
+static const struct snd_soc_dai_ops null_dai_ops = {
 static int soc_bind_dai_link(struct snd_soc_card *card, int num)
diff --git a/sound/soc/tegra/tegra_i2s.c b/sound/soc/tegra/tegra_i2s.c
index 76014f0..1acbb55 100644
--- a/sound/soc/tegra/tegra_i2s.c
+++ b/sound/soc/tegra/tegra_i2s.c
@@ -305,7 +305,7 @@ static int tegra_i2s_probe(struct snd_soc_dai *dai)
 	return 0;
-static struct snd_soc_dai_ops tegra_i2s_dai_ops = {
+static const struct snd_soc_dai_ops tegra_i2s_dai_ops = {
 	.set_fmt	= tegra_i2s_set_fmt,
 	.hw_params	= tegra_i2s_hw_params,
 	.trigger	= tegra_i2s_trigger,
diff --git a/sound/soc/tegra/tegra_spdif.c b/sound/soc/tegra/tegra_spdif.c
index dd11d0c..ea9c920 100644
--- a/sound/soc/tegra/tegra_spdif.c
+++ b/sound/soc/tegra/tegra_spdif.c
@@ -226,7 +226,7 @@ static int tegra_spdif_probe(struct snd_soc_dai *dai)
 	return 0;
-static struct snd_soc_dai_ops tegra_spdif_dai_ops = {
+static const struct snd_soc_dai_ops tegra_spdif_dai_ops = {
 	.hw_params	= tegra_spdif_hw_params,
 	.trigger	= tegra_spdif_trigger,
BtrLinux
Privacy Overview
