ASoC: alc5623: Replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGE
Author: Lars-Peter Clausen <lars@metafoo.de>
DECLARE_TLV_DB_RANGE() has the advantage over using TLV_DB_RANGE_HEAD()
that it automatically calculates the number of items in the TLV and is
hence less prone to manual error.
Generate using the following coccinelle script
declarer name DECLARE_TLV_DB_RANGE;
identifier tlv;
constant x;
-unsigned int tlv[] = {
-	TLV_DB_RANGE_HEAD(x),
+DECLARE_TLV_DB_RANGE(tlv,
Signed-off-by: Lars-Peter Clausen
Signed-off-by: Mark Brown
 sound/soc/codecs/alc5623.c | 7 +++----
 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/sound/soc/codecs/alc5623.c b/sound/soc/codecs/alc5623.c
index 0fc24e0..ebdaf0d 100644
--- a/sound/soc/codecs/alc5623.c
+++ b/sound/soc/codecs/alc5623.c
@@ -82,12 +82,11 @@ static int amp_mixer_event(struct snd_soc_dapm_widget *w,
 static const DECLARE_TLV_DB_SCALE(vol_tlv, -3450, 150, 0);
 static const DECLARE_TLV_DB_SCALE(hp_tlv, -4650, 150, 0);
 static const DECLARE_TLV_DB_SCALE(adc_rec_tlv, -1650, 150, 0);
-static const unsigned int boost_tlv[] = {
-	TLV_DB_RANGE_HEAD(3),
+static const DECLARE_TLV_DB_RANGE(boost_tlv,
 	0, 0, TLV_DB_SCALE_ITEM(0, 0, 0),
 	1, 1, TLV_DB_SCALE_ITEM(2000, 0, 0),
-	2, 2, TLV_DB_SCALE_ITEM(3000, 0, 0),
+	2, 2, TLV_DB_SCALE_ITEM(3000, 0, 0)
 static const DECLARE_TLV_DB_SCALE(dig_tlv, 0, 600, 0);
 static const struct snd_kcontrol_new alc5621_vol_snd_controls[] = {
BtrLinux
Privacy Overview
