sound/soc/codecs/adau1373.c | 21 +++++++++------------
1 file changed, 9 insertions(+), 12 deletions(-)
diff --git a/sound/soc/codecs/adau1373.c b/sound/soc/codecs/adau1373.c
index a431602..1fc1bd4 100644
--- a/sound/soc/codecs/adau1373.c
+++ b/sound/soc/codecs/adau1373.c
@@ -320,13 +320,12 @@ static const struct reg_default adau1373_reg_defaults[] = {
{ ADAU1373_DIGEN, 0x00 },
-static const unsigned int adau1373_out_tlv[] = {
- TLV_DB_RANGE_HEAD(4),
+static const DECLARE_TLV_DB_RANGE(adau1373_out_tlv,
0, 7, TLV_DB_SCALE_ITEM(-7900, 400, 1),
8, 15, TLV_DB_SCALE_ITEM(-4700, 300, 0),
16, 23, TLV_DB_SCALE_ITEM(-2300, 200, 0),
- 24, 31, TLV_DB_SCALE_ITEM(-700, 100, 0),
+ 24, 31, TLV_DB_SCALE_ITEM(-700, 100, 0)
static const DECLARE_TLV_DB_MINMAX(adau1373_digital_tlv, -9563, 0);
static const DECLARE_TLV_DB_SCALE(adau1373_in_pga_tlv, -1300, 100, 1);
@@ -381,12 +380,11 @@ static const char *adau1373_bass_hpf_cutoff_text[] = {
"158Hz", "232Hz", "347Hz", "520Hz",
-static const unsigned int adau1373_bass_tlv[] = {
- TLV_DB_RANGE_HEAD(3),
+static const DECLARE_TLV_DB_RANGE(adau1373_bass_tlv,
0, 2, TLV_DB_SCALE_ITEM(-600, 600, 1),
3, 4, TLV_DB_SCALE_ITEM(950, 250, 0),
- 5, 7, TLV_DB_SCALE_ITEM(1400, 150, 0),
+ 5, 7, TLV_DB_SCALE_ITEM(1400, 150, 0)
static SOC_ENUM_SINGLE_DECL(adau1373_bass_lpf_cutoff_enum,
ADAU1373_BASS1, 5, adau1373_bass_lpf_cutoff_text);
@@ -414,11 +412,10 @@ static SOC_ENUM_SINGLE_DECL(adau1373_3d_level_enum,
static SOC_ENUM_SINGLE_DECL(adau1373_3d_cutoff_enum,
ADAU1373_3D_CTRL1, 0, adau1373_3d_cutoff_text);
-static const unsigned int adau1373_3d_tlv[] = {
- TLV_DB_RANGE_HEAD(2),
+static const DECLARE_TLV_DB_RANGE(adau1373_3d_tlv,
0, 0, TLV_DB_SCALE_ITEM(0, 0, 0),
- 1, 7, TLV_DB_LINEAR_ITEM(-1800, -120),
+ 1, 7, TLV_DB_LINEAR_ITEM(-1800, -120)
static const char *adau1373_lr_mux_text[] = {
"Mute", |
