ARM/sa1111: Prepare sa1111_irq_handler for irq argument removal
Author: Thomas Gleixner <tglx@linutronix.de>
The irq argument of most interrupt flow handlers is unused or merily
used instead of a local variable. The handlers which need the irq
argument can retrieve the irq number from the irq descriptor.
Search and update was done with coccinelle and the invaluable help of
Julia Lawall.
Signed-off-by: Thomas Gleixner
Cc: Julia Lawall
Cc: Jiang Liu
Cc: Russell King
Cc: linux-arm-kernel@lists.infradead.org
 arch/arm/common/sa1111.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/common/sa1111.c b/arch/arm/common/sa1111.c
index 71a2198..94e3780 100644
--- a/arch/arm/common/sa1111.c
+++ b/arch/arm/common/sa1111.c
@@ -197,8 +197,9 @@ static struct sa1111_dev_info sa1111_devices[] = {
  * will call us again if there are more interrupts to process.
 static void
-sa1111_irq_handler(unsigned int irq, struct irq_desc *desc)
+sa1111_irq_handler(unsigned int __irq, struct irq_desc *desc)
+	unsigned int irq = irq_desc_get_irq(desc);
 	unsigned int stat0, stat1, i;
 	struct sa1111 *sachip = irq_desc_get_handler_data(desc);
 	void __iomem *mapbase = sachip->base + SA1111_INTC;
BtrLinux
Privacy Overview
