ARM/pxa: Prepare *_irq_handler for irq argument removal
Author: Thomas Gleixner <tglx@linutronix.de>
The irq argument of most interrupt flow handlers is unused or merily
used instead of a local variable. The handlers which need the irq
argument can retrieve the irq number from the irq descriptor.
Search and update was done with coccinelle and the invaluable help of
Julia Lawall.
Signed-off-by: Thomas Gleixner
Cc: Julia Lawall
Cc: Jiang Liu
Cc: Russell King
Cc: linux-arm-kernel@lists.infradead.org
arch/arm/mach-pxa/cm-x2xx-pci.c | 3 ++-
arch/arm/mach-pxa/lpd270.c | 3 ++-
arch/arm/mach-pxa/pcm990-baseboard.c | 3 ++-
arch/arm/mach-pxa/viper.c | 3 ++-
arch/arm/mach-pxa/zeus.c | 3 ++-
5 files changed, 10 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-pxa/cm-x2xx-pci.c b/arch/arm/mach-pxa/cm-x2xx-pci.c
index d8f816c..1fa79f1 100644
--- a/arch/arm/mach-pxa/cm-x2xx-pci.c
+++ b/arch/arm/mach-pxa/cm-x2xx-pci.c
@@ -29,8 +29,9 @@
void __iomem *it8152_base_address;
static int cmx2xx_it8152_irq_gpio;
-static void cmx2xx_it8152_irq_demux(unsigned int irq, struct irq_desc *desc)
+static void cmx2xx_it8152_irq_demux(unsigned int __irq, struct irq_desc *desc)
+ unsigned int irq = irq_desc_get_irq(desc);
/* clear our parent irq */
desc->irq_data.chip->irq_ack(&desc->irq_data);
diff --git a/arch/arm/mach-pxa/lpd270.c b/arch/arm/mach-pxa/lpd270.c
index eaee2c2..799d869 100644
--- a/arch/arm/mach-pxa/lpd270.c
+++ b/arch/arm/mach-pxa/lpd270.c
@@ -120,8 +120,9 @@ static struct irq_chip lpd270_irq_chip = {
.irq_unmask = lpd270_unmask_irq,
-static void lpd270_irq_handler(unsigned int irq, struct irq_desc *desc)
+static void lpd270_irq_handler(unsigned int __irq, struct irq_desc *desc)
+ unsigned int irq;
unsigned long pending;
pending = __raw_readw(LPD270_INT_STATUS) & lpd270_irq_enabled;
diff --git a/arch/arm/mach-pxa/pcm990-baseboard.c b/arch/arm/mach-pxa/pcm990-baseboard.c
index 2897da2..1622675 100644
--- a/arch/arm/mach-pxa/pcm990-baseboard.c
+++ b/arch/arm/mach-pxa/pcm990-baseboard.c
@@ -284,8 +284,9 @@ static struct irq_chip pcm990_irq_chip = {
.irq_unmask = pcm990_unmask_irq,
-static void pcm990_irq_handler(unsigned int irq, struct irq_desc *desc)
+static void pcm990_irq_handler(unsigned int __irq, struct irq_desc *desc)
+ unsigned int irq;
pending = ~pcm990_cpld_readb(PCM990_CTRL_INTSETCLR);
diff --git a/arch/arm/mach-pxa/viper.c b/arch/arm/mach-pxa/viper.c
index de3b080..687554b 100644
--- a/arch/arm/mach-pxa/viper.c
+++ b/arch/arm/mach-pxa/viper.c
@@ -276,8 +276,9 @@ static inline unsigned long viper_irq_pending(void)
viper_irq_enabled_mask;
-static void viper_irq_handler(unsigned int irq, struct irq_desc *desc)
+static void viper_irq_handler(unsigned int __irq, struct irq_desc *desc)
+ unsigned int irq;
pending = viper_irq_pending();
diff --git a/arch/arm/mach-pxa/zeus.c b/arch/arm/mach-pxa/zeus.c
index ac2ae5c..0bba62c 100644
--- a/arch/arm/mach-pxa/zeus.c
+++ b/arch/arm/mach-pxa/zeus.c
@@ -105,8 +105,9 @@ static inline unsigned long zeus_irq_pending(void)
return __raw_readw(ZEUS_CPLD_ISA_IRQ) & zeus_irq_enabled_mask;
-static void zeus_irq_handler(unsigned int irq, struct irq_desc *desc)
+static void zeus_irq_handler(unsigned int __irq, struct irq_desc *desc)
+ unsigned int irq;
pending = zeus_irq_pending(); |
@@ -29,8 +29,9 @@
+ unsigned int irq;
+ unsigned int irq;
+ unsigned int irq;
+ unsigned int irq;
